SUPPORT OUR SPONSOR
Old 05-09-2002, 02:00 PM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Question Help..AN4 adapter for Tilton cylinders
I can't find the catalog or article that showed this part.
It was a billet adapter that replaced the plastic adapter on the Tilton master cylinders for the remote mount reservoir.
I am using the Girling reservoirs from Cobra Restorers and want to run a #4 s/s braided line between the cylinder and reservoir.
Anybody else seen this part ???
Cheer,
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 05-10-2002, 08:12 AM
Default help..again
any ideas ???
Bill Cook
Old 05-10-2002, 09:07 AM
I've never seen one, and I'd have my doubts about how reliable the O-ring seal would be. How about running a -5 or -6 (I forget which) off the nipple, with a clamp? Earls makes a fake nipple with the clamp semi-hidden inside.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 05-10-2002, 05:26 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
I have seen something similar, but the owner had just cut the nipple off the Tilton head, and installed a bulkhead fitting thru the plastic cap and added ring sealant. He said there were no problems, and that the seal was airtight after he installed the hot seal. Shouldn't be a problem, as the top of the master cylinder doesn't get put under pressure.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 05-10-2002, 07:11 PM
Thumbs up 427sharpe
Great idea.
Will give it a go!!!
Bill Cook
Old 05-10-2002, 07:34 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Please share results
Bill, I have the same 4AN fitting on the remotes and want to install flex lines between the remotes and master cylinders. Please post your results (with pics). Thanks
HTML code is On
