Old 08-19-2002, 08:58 AM
Cobra Make, Engine: SPF - 427 Stroker
Default Spf - Red Indicator Light ???
Can anyone tell me what the red light just above the ignition key is for on an SPF ?? Mine just came on yesterday...Thanks in advance.
NEVER LIFT
Old 08-19-2002, 09:04 AM
Dan Semko's Avatar
Hoosier Gashole Emeritus
Wink Watch your alternator
Agro,
It's the ignition light and if it comes on and stays on, start watching your amp gauge. When the amp gauge starts to dance in the discharge area, it's a pretty good indicator that your alternator is about to go on vacation. If you replace it, I suggest that you contact Mark Dove at Dynamic Motorsports and ask about the Roush Racing 90 amp alternator. It may save you some headaches in the future.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 08-19-2002, 09:05 AM
Mr.Fixit's Avatar
Don't wory about it. Your charging system is still working, right?
Old 08-19-2002, 09:11 AM
Default Charging System...
...seems to be working fine. Car fires right up and runs perfectly. What would indicate that the charging system is NOT working ?? Could it be an indication that the alternator is getting ready to go bad ?
NEVER LIFT
Old 08-19-2002, 09:26 AM
Cobra Make, Engine: SPF #1019
Could be a weak or broken ground... I had this problem before.
Good luck,
Randy R...
Old 08-19-2002, 09:30 AM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Post Alternator/Voltage Rgulator Problem....
The red light indicates the alternator or voltage regulator is not putting out enough power. When you first turn the switch to the 'ON' position, the light glows because the alternator isn't turning and producing power. It should go out once the car is started and running. If not, suspect a bad alternator, or voltage regulator.
Since I don't know if you're running an alternator with an internal voltage regulator, or not, I can't be sure if your voltage regulator could be the problem. Normally, for internal voltage regulators the red light will glow if a diode goes bad in the regulator. This causes a back circuit that will run down your battery while the car is off. It normally causes the red light to glow a little - sometimes very faintly - when the car isn't running.
I'd remove the alternator and take it to a shop that can test it. I suspect a bad alternator. It won't show up immediately, but this will run your battery down PDQ.
If the alternator tests good, then I'd suspect a bad regulator. They're inexpensive, and if it's in question - replace it. If that still doesn't solve the problem, then I'd suspect a faulty, or intermittent ground somewhere.
Finally, it may even be a faulty igniton switch...pretty remote, but it could happen.
Hope this helps...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 08-19-2002, 09:45 AM
Roscoe's Avatar
agro,
Just remember if you install a 90 amp alternator then DO NOT hook it up to your amp gauge.
Roscoe
Roscoe
Old 08-20-2002, 02:38 PM
Alternator seems fine...Replaced the voltage regulator and the light went off, but the system still does not seem to be charging...DAMM - any ideas ?
NEVER LIFT
Old 08-20-2002, 02:51 PM
Mr.Fixit's Avatar
use a voltmeter to verify if it is running at 13.5-14.5 volts.If it is not charging it will be closer to 12.0
Bypass the ammeter by connecting the two big red wires that plug into the backside of it and check volts again with car running
Make sure the sise terminal on the starter solenoid bolted to the firewall is tight. The one with the 10 ga red wire
Check the 3 wire connector that connects the regulator loom to the rest of the car, one terminal may have pushed out.
Is the brown ground wire atached to the case of the regulator?
Does your car have an MSD... if so there may be a diode inline between the "I" terminal on the regulator and the alternator, this may be fried. Other than that, just check all connection points and contiuity test the loom between terminals to verify no broken or loose wires.
Old 08-20-2002, 02:52 PM
Did you have the alternator checked...? If not, how do you know the "alternator seems fine"? Not trying to get on your case, but faulty alternators look just like good ones....they just don't charge....and what were your symtoms again?
Seriously, check out that alternator. Sounds like you may have had a flakey voltage regulator because your red light went out when it was replaced. Now, we need to be sure your alternator doesn't have a broken field coil, or something else that's causing it not to produce a charge. A shop specializing in starters/alternators should be able to check it for you for little or nothing. But, you'll have to take it off and take it to them first.
If your alternator checks okay, and you know you've already replaced the voltage regulator, hell, the only thing left is wiring....maybe a bad ground wire, loose or intermittent contact, bad battery - maybe, but probably not. Faulty or intermittent ground wires would probably be in your ammeter circuit. I'd be willing to bet everything's okay with your alternator, voltage regulator, and battery, but your ammeter has fried it's guts....just a guess here.
Check out that alternator and let us know what turns up.
Anyone else got any more ideas....?
Flyin_Freddie
Old 08-20-2002, 02:53 PM
As per usual - great advice !! Thanks Fixit, looks like I have some hunting to do !!
NEVER LIFT
Old 08-20-2002, 03:01 PM
...The car is in the very able and competent hands of House of Cobras for it's 500 mile service. I'm sure they will find the prob - just hope it's not the alternator...Thanks for the help though, much appreciated...
NEVER LIFT
Old 08-20-2002, 03:13 PM
Thumbs up
Sounds like MrFixIt and I are on the same page. I didn't think of bypassing the ammeter, but his suggestion is a good one. Don't forget to disconnect the battery before messing around with the back of the ammeter, or you'll get a whole new appreciation of Forth of July fireworks! Yeeeeee-haaaa!
Don't ask me how I know that....or about how hot wires get welded to metal devices they're not supposed to be welded to. I have no idea....
Flyin_Freddie
Old 08-21-2002, 07:45 AM
Wayne Maybury's Avatar
Canadian Gashole
Come on Freddie, tell us how you learned all about welding wires together. We want to have details.
Wayne
Old 08-21-2002, 08:02 AM
Talking Weeeelllllll......
Let's just say I have a new in-depth understanding of the principles and physics of arc welding, and leave it at that,...okay?
Flyin_Freddie
Old 08-21-2002, 12:38 PM
Canadian Gashole
Wink OOOOOOOOOOOOOOOOK
I'm assuming that you weren't using a welding machine at the time. Is that correct?
Wayne
Old 08-21-2002, 12:48 PM
Oui...
Flyin_Freddie
Old 08-21-2002, 07:20 PM
FOCS's Avatar
Just had the alternator replaced on #1299 and picked her up today. I have only driven the car a couple of times at night and noticed that the indicator light was on. I really could not tell if if it was on during the daytime. Stupid me, when I saw it on I just figured that it meant that the ignition was on. I'll have to admit that on those night time drives I said to myself "man that red light is kind of annoying"!!! Anyway, all is well now and the car is running superb. BTW, I also had the new "Pro whatever its called" shifter linkage installed........what a great set-up, I would highly recommend it.
Brian "gotta read the owners manual" Newell
p.s. many thanks to Eric @ Performance Engineering. This guy is top notch!!!!
