| 29 |
10-08-2002, 08:35 PM
MO
Too much lube?
A small amount of lube has come out of the breather cap on the top of my Cobra's 9" rear end / axle. More of a weep, not much has come out, just enough to notice.
Should I attempt to drain off some of the lube or forgetaboutit?
Pete K.
Who is John Galt?
10-08-2002, 10:04 PM
OR
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Pete,
I may be nuts,but did you by chance fill that rear end before installing it under the car? It could be that there's too much lube in it. Pull the fill plug and see what happens. Let it drain until it quits flowing and put the plug back in. wipe it all off clean and see if the weep is gone.
The full level is level with the bottom of the plug. Some units have a small plug in the very bottom. Don't make the mistake of pulling that one or you'll lose all of the oil.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
10-09-2002, 12:09 AM
Yeah mine used to "weep" out the "breather" too. After running it HARD on the track especially. I put a rubber hose on the "nipple" at the axle and ran it up higher than the rear end. Solved the problem nicely, no more " oil stains". I go fast, but want to look good to, lol.
Ernie
10-09-2002, 07:19 AM
NJ
I did the same thing as Ernie and it works fine.
Roscoe
Roscoe
10-09-2002, 07:22 AM
Cal
One foot of 3/8" rubber hose run as described by Excaliber above works well, SPF does it from the factory
10-09-2002, 07:48 AM
MO
I filled the diff when the rear was on the car. I'll pull the fill plug just to make sure that I didn't over fill ... and then add a length of moon-glow fake stainless braid hose to the vent.
THANKS EVERYONE!
Pete K.
Who is John Galt?
10-09-2002, 09:27 AM
Ewwwww,,,,,,,,moon glow stainless braid, sounds better than my rubber hose approach, ha ha.
Ernie
10-09-2002, 10:03 AM
Cal
Black rubber, that way nobody sees the damn thing. Besides, anything on the underside doesn't stay shiny long anyway.
10-09-2002, 11:27 AM
MO
Yeah, but *I* will know it's there
And doesn't *everyone* wax the undersides of their Cobra!
Pete K.
Who is John Galt?
10-09-2002, 01:42 PM
IL
Jeff
Mark Donahue
10-09-2002, 07:43 PM
MO
I think I'm already pushing my luck with the Lucas toggle switches!
Pete K.
Who is John Galt?
