SUPPORT OUR SPONSOR
Old 10-12-2002, 10:37 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default ARP lube or ?
I have 1/2" studs on my FE w/ aluminum heads .The tops are 1/2"x 20 NF.George Anderson said the touque should be 85ftlbs W/ARP molly assembly lube.I don't have that stuff.What else will work as well .OR what torque w/ just engine oil? Remember alluminum heads and 1/2' x 20 threads.
Mike H
Old 10-12-2002, 10:51 PM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
Any light weight grease should be fine. Torque figures are fauge compared to todays methods which you tighten to a very light torque, then turn the nut or bolt so many degrees.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 10-12-2002, 11:22 PM
Andy Dunn's Avatar
Send a message via ICQ to Andy Dunn
ARP does recomment 85lbs with aluminum heads and ARP moly. It is the last line on this green instruction sheet.
http://www.cobralads.com/mystery/DSC00102.JPG.html
with motor oil, ARP recommends 108 on their general fastener torque recommendation page
http://www.arp-bolts.com/pages/tech/images/fasttorq.pdf
If you have some moly grease or thick grease around, I think you can go closer to the 85.
Andy
Display Modes
HTML code is On
