Old 10-21-2002, 01:54 PM
Cobra Make, Engine: 2003 Ford Cobra Mustang
Send a message via ICQ to LateApex Send a message via AIM to LateApex
Default Non-Cobra tranny question--blasphemy I am sure
Don't spend much time on this, I just figure someone may know off the top of their head. I am building a 392 Hemi motor for a streetrod project. I can get tranny adaptors for either Chrysler or Chevy/GM style manual trannies from one particular source.
I want to run a 6 speed if I can. Ideally a Richmond 6 speed (new improved version of the Doug Nash 5 speed--they bought the tooling), also a T56, or ZF ( from the pre-94 Vettes, a little too bulky though) may work.
Does anyone know if the Richmond would support the bolt patterns on a bellhousing adaptor made for a GM or Chrysler manual tranny? Are there any sites that one can reference for tranny interchangeability etc? I obviously realize the drive shaft will be custom for this app, and the clutch set up may or may not be a one-off.
Old 10-21-2002, 02:31 PM
flipper35's Avatar
You may try Keisler (sp?) Engineering for a bellhousing to fit. Hays may also have a non-SFI approved bellhousing for you. Clutch set-up should be easy. Matching the input shaft to crankshaft bushing/bearing may be. I am sure a performance machine shop could drill and machine the proper bolt pattern for you also.
Brent Dolphin
Old 10-21-2002, 04:30 PM
Aussie Mike's Avatar
Sallee Chevrolet sell a T56 with an adaptor plate that will bolt up to a standard Chev bellhousing.
check it out http://www.sallee-chevrolet.com/BorgWarner/t56pics.html
Mike Murphy
Melbourne Australia
Old 10-21-2002, 05:50 PM
I love this site. Thanks guys. Seems you each have a piece of my puzzle--one Mopar powered, the other with one of the trannys I am thinking of. Aussie Mike, your car will win the driveability award--that will be a nice set up.
I am glad, as the Sallee Chevy link may be useful down the road for someone with a Cobra. My Cobra is a BB 427 with a 4spd toploader, so none of this one-off stuff came up before.
Old 10-21-2002, 06:20 PM
Ain't this site good, I've gotten so much info from people on here. It sure makes the build easier when you know there are a bunch of people to answer your questions only a few keystrokes away.
What sort of Rod is the hemi going into? always been a fan of that motor myself. Looks powerful just sitting there.
Mike Murphy
Melbourne Australia
Old 10-21-2002, 11:39 PM
LateApex - why Re-invent the wheel? 392 Hemis have the smallblock tranny bolt pattern and most rod guys use a 904/727 smallblock pattern torque-flight if memory serves me right. If that is so, and I think it is, a performance smallblock bellhousing will bolt right up and and a Chrysler 4 speed common on 340 and 273 performance cars of the 60's and 70's will fit, though I seem to remember something about cutting down the input shafts of trannys to make them fit by one inch. Try calling ;
www.hothemiheads.com to get the straight scoop. They sell tranny adapters too if I recall, and I don't recall right.
cobrashoch
Ron Shockley
Old 10-22-2002, 11:06 AM
flipper35's Avatar
Ron, I think he is looking for a 6-speed tranny. But if he wants an 833, Brewers Performance in OH has some. Keisler makes a complete setup including a TKO II 5 speed for just under 3 grand. Includes new bearings for the crankshaft, machined bellhousing, correct spacing and everything. Hays makes a bellhousing NOT SFI approved with a T-10 bolt pattern and spacing. That will require a different bushing/bearing on the crank.
On a side note, the 904 is the biggest piece of crap since the dinosaurs died.
Brent Dolphin
Old 10-22-2002, 01:30 PM
Well after a day's worth of digging, Seems Hot Hemi Heads and a company called Calpana can come up with what I need.
calpana is at www.wilcap.com
Old 10-23-2002, 07:54 AM
Flipper - Right on about the 904. I have a friend that is using a 904 that had a big block pattern welded on the front of the housing from a old 727. Runs it in "B" stock and that car runs its index and better. He's not touched that tranny in 4 years that I know of either. Does make you think, doesn't it? Remember, there was a time a few years ago that low gear sets could only be had for 904's
cobrashoch
Ron Shockley
Old 10-23-2002, 09:45 AM
flipper35's Avatar
I blew up 2 904's in 2 different cars. On the street running on twisty back roads, lots of shifting, neither were very strong cars.
Brent Dolphin
