Old 10-25-2002, 10:30 PM
Default Torque settings for re-installing a clutch
Can someone please tell me what to lbs to torque the flywheel bolts to?
Also what to torque the pressure plate to???
I am using a 95 flywheel, which using metric threaded bolts...
I got some bolts from a hardware store, I sheared one one head... Someone told me to torque the pressure plate to 50 lbs... Now I am thinking that statement might be wrong...
Thanks...
Old 10-27-2002, 05:09 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
According to my small block ford book....
Flywheel - 75 to 85 pounds
Clutch Plate - 12 to 20 pounds
and get the right bolts. Either after market flywheel/clutch bolts or from a Ford dealer. Don't mess with the hardware store stuff here. Plus the Ford bolts come with a thread locker allready applied.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 10-27-2002, 09:33 AM
ERA 626's Avatar
I just went through this.
I am not sure about the pressure plate but the flywheel:
60lbs if using arp lube
75-80lbs if using oil
hope this helps
PS USE ARP BOLTS!!!!!
Old 10-29-2002, 08:19 AM
Mr.Fixit's Avatar
85 on the flywheel, 22 on the PP get new bolts too, don't reuse those old stretchy ones.
