SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-17-2002, 08:59 PM
Question Moving to 5 speed: NO pedal room!
I have an older NAF Cobra with an automatic. I would like to changeover to a 5 speed, but the foot box is extremely tight. I have a Tilton pedal and brake system mounted on the firewall, with a conventional, small gas pedal. The horizontal clearance is so tight already that I have to tuck my left foot way back to hit the brakes. Any suggestions on a brake and clutch assembly that is engineered for tight fits? Tilton has some options, but they all look to be sized fairly standard. My other option is to modify the size of the footbox (MPITA)...
rmb_cobra
FST S HL
Old 11-18-2002, 07:42 AM
aumoore's Avatar
Cobra Make, Engine: Hunter 427, 5.0 (302)
chop off a few toes and wear womens shoes
I have a Hunter Cobra and am using the Wilwood three master cylinder dual pedal setup. There is no room for wide shoes so cross trainers are out. The wilwood dual pedal setup has the correct spacing on the pedals so you need to start from the left and work out the gas pedal as far to the right as you can.
Does your cobra have a inner liner on the left side of the foot box? If so you might be able to remove part of it and open up a little more room for your clutch pedal. Many cobras have just the outside of the body for the inside of the footbox. My cobra has a thin piece of plywood covered in black vinyl and I have thought about cutting off the part next to the clutch pedal and gluing carpet to the inside of the body/footbox.
Cobras are not made for people with big feet or bodies.
Click here for DSCC website
Old 11-18-2002, 08:23 AM
Cobra Make, Engine: 65 la exotics 351W supercharged
I have a B & B and had the same issue, plus size 13 feet. By removing the panel next to the clutch, making the pedals smaller,
and heating the pedal arms to move them back & forth I made it
work. Jay
Display Modes
HTML code is On
