SUPPORT OUR SPONSOR
Old 02-19-2003, 01:59 PM
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
Default Removing coolant spray from engine bay
Anyone have a great and easy on the elbow grease method of removing coolant/anti-freeze spray from inside the engine bay?
My expansion tank developed a weak weld on one of the hose elbow fittings and has been "spritzing" coolant for several months all over my engine bay. I used elbow grease and water on the hood underside, but as some of you know, antifreeze is a nice gooey, sticky, slimy mess after several months of exposure to air and heat. I was going to start with Simple Green or Greased Lightning (which is more PH neutral) and hose it down.
Old 02-19-2003, 03:03 PM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Rag sprayed with WD 40?
Worked for me, but I couldn't say if it is the easiest way of all.
Wilf
Old 02-19-2003, 03:17 PM
Thanks Wilf. Cheers.
Old 02-19-2003, 04:00 PM
Try a solution of dishwashing liquid (Dawn is pretty good on greasy stuff) and water, perhaps with a bit of lemon juice.
TT
Old 02-19-2003, 04:36 PM
Cobra Make, Engine: Old car with 6 banger
TC
Spyderman says he cleans his engine bay with beer
DC
Old 02-19-2003, 04:50 PM
Dave unfortuntately that's usually beer he already swallowed earlier in the evening
Old 02-19-2003, 05:12 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Why not just drive down to the friendly corner self serve car wash and use the spray wand? That has worked for me.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Display Modes
HTML code is On
