SUPPORT OUR SPONSOR
Old 04-22-2003, 03:49 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default cfm
is 30cfm at the peak lift of a said cam worth much hp?
Old 04-22-2003, 09:49 AM
RallySnake's Avatar
The quick answer is: at low RPM it may be a drawback, at high RPM an advantage. If you give more specifics (engine size, intake manifold type, exhause header size, carb size and all the cam specs, someone here can probably give you a much better answer.
Paul
Old 04-23-2003, 01:34 AM
347's Avatar
347 347 is offline
347,10.1comp,quad 44mm idf webers,1 3/4 4into1 headers,solid flat cam 560 lift ,248@.050,110 lobes,the extra 33cfm comes from 48mm ida's with 42 mm chokes....any takers?
Old 04-23-2003, 02:14 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
With some info missing...the computer says roughly 40 lbs of torque and 50 horse, but this is all speculation, as other things are involved...I.E. can you heads flow another 30 cfm
Jack
XSSIVE .....
Old 04-23-2003, 04:51 AM
347's Avatar
347 347 is offline
yes they can, the 33 cfm comes from having the head/manifold,carb flowed ,the difference between the 44 and the 48's on the flow bench is 33cfm at 560lift
intake port flows 288cfm @.560lift
head/manifold flows 280cfm@.560lift
head/manifold/48's flow 256cfm@.560lift
44's 33cfm less @.560lift
the heads are ported alloy windsor snr's
if i was to run a four barrel,would i see flow of 280plus @.560lift?
Old 04-23-2003, 05:05 AM
Hotfingrs's Avatar
Look at AFR website...their SBF 205 heads flow 291cfm @ .500 lift
Jack
XSSIVE .....
HTML code is On
