SUPPORT OUR SPONSOR
Old 04-27-2003, 09:02 AM
Default 351 Alternator Location
I HAVE 351W CRATE MOTOR WITH EXPANSION THAT BOLTS INTO THE THERMOSTAT HOUSING[ PURCHASED FROM ENZO ] . I HAVE BEEN UNABLE TO USE THE MARCH ALTERNATOR BRACKET BECAUSE IT MOUNTS THE ALTERNATOR TOO HIGH[ AT THE LEVEL OF THE VALVE COVER] AND THE EXPANSION TANK IS IN THE WAY...WHAT TYPE/BRAND OD ALTERNATOR BRACKET CAN I USE TO PUT THE ALTRNATOR LOWER[ NEARER THE LEVEL OF THE WATER PUMP]...I'M ALSO USING MARCH PULLEYS, V-BELT, NO POWER STEERING...THANKS
Old 07-06-2005, 04:22 AM
Cobra Make, Engine: RUCC Cobra, 351W 400hp / 400 lbs torque
Did you ever find a bracket to relocate your alternator. I am running into the exact same problem, any help or suggestions would be greatly appreciated.
Jim
Old 07-06-2005, 06:15 AM
Cobra Make, Engine: SPF 974
Nick at Classic Concpets should be able to sell you the right brackets . Give him a call at 631-643-4611.
Old 07-06-2005, 06:20 AM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I had exactly the same problem. Several dealers offer a set of brackets for the 351W that will mount the alternator on the passenger side of the motor in a "Low" location with the alternator pully approximately level with the water pump pully. There is at least one such set offered on eBay made of polished stainless steel, another set offered in aluminum. Good Luck.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 07-06-2005, 09:02 AM
Cashburn's Avatar
Backdraft Racing Dealer
Get the Roush bracket. We don't stock yet but Jegs does.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
HTML code is On
