SUPPORT OUR SPONSOR
Old 05-26-2003, 07:36 PM
Tony: I bought a harness from EZ Wire - 12 Circuits-11 Fuses * Horn relay & connector *Turn & hazard signals *Dimmer switch connector *Circuit breaker for headlights *2 Flashers *1 Alternator plug *2 Ignition switch connectors *Fuse panel pre-wired *1 Grommet *8 yellow splice connectors *6 Blue splice connectors *6 Small blue lugs *5 Medium yellow lugs *2 Large lugs (one with fusible link) *Small tie wraps *Wires labeled every 5 inches (all black wires). $165. Colored wires cost $160. The directions were not the best, but as mentioned in other posts, these cars are pretty simple. Wire gauges are the same as the expensive harnesses. ezwiring.com/12_circuit_harness.htm
HTML code is On
