SUPPORT OUR SPONSOR
Old 05-26-2003, 08:10 PM
Default Carpeting questions..how much material?
Hi gang
For those who have been there, how much carpet in sq yrds or what have youi will do the cars cockpit??
My builder also said he uses black trunk felt to do the more tricky compound curve areas ( like the fender caps) He uses lots of sections and some get bound edges if they happen to be the topmost pieces.
He uses underlay sparingly so as to not bulk up certain areas. I think only the tunnel top, footbox tops side etc
Just basically want to know this amount so I can order an amount with a little extra from an upholstery shop...you know the confident "I need so many sq yards" answer......LOL
oh yeah .....he said lots of spray on industrial strength glue.
He didn't tell me how much material because he farms this job out to an upholstery shop!
Tim
Old 05-26-2003, 08:30 PM
I just installed a foam/insulation bond to my interior. I did the complete area, floor, foot boxes, trans tunnel and behind the seats with a roll 60" x 120" and had a very small amount left over.
Old 05-27-2003, 02:16 PM
Chifo
TY for the response...
looks like whatever one uses a roll/piece 5 by 10 ft should cover it
What was the material you were using in this application..simple underlay or was it the aluminum backed thermal barrier some speak of?
Tim
Old 05-27-2003, 03:21 PM
Cobra Make, Engine: Unique FIA
Thumbs up
Tim,
I would talk directly to the upholstery shop if I were you. Great thread. I'm going to do my Unique's carpet, so this info will be helpfull thanks.
Steven
All my ex's live in Texas
Old 05-27-2003, 03:25 PM
The insulation I used was a closed cell foam with an aluminized thermal barrier bonded to the rear. Its a bit more costly than the pad/aluminized but what I really liked about it is that it will not take on any water due to the closed cell foam. For an open top car this was quite a plus in my mind.
Old 05-28-2003, 05:49 PM
Where is this available from?
Old 05-28-2003, 06:07 PM
Are you asking about the insulation?
Old 05-28-2003, 07:06 PM
Yes. The type with the foam and foil.
Thanks
Old 05-29-2003, 08:54 AM
You can buy it from Larry Phillips at Prorod. He can be reached at 760/746-5518 or by email at prorod940@aol.com. It should be between $60 and $80 to do your interior complete. A bit more but you wont have mold/mildew problems like with the jute based insulations.
Old 05-29-2003, 04:05 PM
Thanks for the reply. I'll give him a call.
Display Modes
HTML code is On
