Old 06-23-2003, 04:34 AM
Cobra Make, Engine: CSX4402
Default flywheel inspection cover help
My 351C is mated to a Tremec 6 speed. It seems that in South Africa someone 'lifted' or it never had the cover plate installs which covers the lower part of the flywheel. Where does one turn to purchase such an inspection cover, size of nuts etc. as I live in Switz. this will surely be impossible in Europe.
Many thanks
Ed
Old 06-23-2003, 05:19 AM
Ron61's Avatar
Post
Ed,
I had one made out of stainless. It never cost much and as for the bolts I just tried a few until I found which ones fit and were the correct length and that was that.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-23-2003, 08:09 AM
Mr.Fixit's Avatar
The cover is determined by your bellhousing, not your tranny.
Old 06-23-2003, 12:02 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I got my 351C rear cover off ebay ( www.ebay.com ). It ran something like $20.00.
I got my bolts from www.fastenal.com. They are grade 8 and work great.
If you are asking about the three bottom bolts, in the US, they are 1/4 x 20 x 1/2 ( use 3/4" and a washer )
Hope this helps.
Old 06-24-2003, 12:56 PM
Could I be confusing something called the "engine blocking plate" with this cover. What exactly do you call this cover- "Fly wheel inspection cover? I am totally confused having spoken to Rockland Standard Gears today (where I got the T56 who told me that the piece is part of the motor) and then called Forte's Parts in Burlington, MA and was told that the part is very important as it acts to "locate" the starter motor so it does not rely on 2 bolts. I could have misunderstood Mike at Forte's who was very helpful and will email me photos. I will try to see if I can get a photo of exactly what seems to be the problem. It seems that in order to fit the engine blocking plate you need to split engine from tranny and the stinking little piece is only a $50 item.
thanks for any clarifaction and sorry for the "dumb questions".
Old 06-24-2003, 03:19 PM
Mr.Fixit's Avatar
I am not familiar with the T56 off the top of my head, but all manual trannys have: and engine plate that goes between the back of the engine and the flywheel, the bellhousing, and some have a cover on the bottom that reveals the bottom third of the flywheel's teeth. You will need to remove the tranny, clutch, disk and flywheel to install a motor plate.
Old 06-25-2003, 01:46 AM
I can only hope this is the plate which covers the bottom third and has nothing to do with engine plate.
Old 06-25-2003, 07:47 AM
trularin's Avatar
Member of the north
ED!
Read your email!
Trularin
