SUPPORT OUR SPONSOR
Old 06-29-2003, 12:56 PM
Cobra Make, Engine: CSX4402
Default turkey pan??
What is the general view about running a turkey pan on a 351C with 750 Holley double pumper? Does it make much difference?
thanks,
Ed
Old 06-30-2003, 05:27 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
If your talking pan vs no pan i think it makes a difference. This was used as a sort of cold air box. It helps keep hot air from underhood going into the engine. Using the scoop to feed it fresh cold air. Just check your pan/hood clearance. Not sure if your question was carb related also.G.
Old 06-30-2003, 05:36 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I was reading something on the Barry Grant site just today that said that you'll see roughly a 1 percent increase in horsepower for every 10 degrees that you can lower the temperature of the air being fed into the intake.
HTML code is On
