SUPPORT OUR SPONSOR
Old 06-30-2003, 09:21 PM
juanone's Avatar
Cobra Make, Engine: SPF 1649, Steel Gray with Silver stripes 427W/565hp stroker from Performance engineering
Default Coolant level on Superformance radiator tank
I need help. Just took delivery of SPF 1649 with 427W. I am having trouble with losing the engine coolant. The first time it did it was because I left the valve on the expansion tank open therefore coolant came out. As a result I panicked and bought Coolant and topped of the stainless steel tank. The next day took the car for a ride and everything was going ok until I shut the engine off. Then steam started coming from under the hood and coolant came out again.
I believe that I may have overfilled the tank after the first incident causing the coolant to come out again.
I drained the overflow tank and closed the valve. I have not started the engine because now I don't know how much coolant to add. What should be the fill level on a cold engine in the stainless steel tank of a Superformance?
Any help is welcome.
juanone
Juan Lopez-Bonilla
Kentucky Cobra Club
2432 Crittenden Drive, Suite 201
Louisville, KY 40217
502-635-5711
juanlb@lbrllc.net
Old 07-01-2003, 08:09 PM
Cobra Make, Engine: Car sold - SPF, Roush 402- Royal Blue-white stripe
Default Coolant overflow
I had a bit of the same. First, re high heat- Fellow SPF owners advised to check my elec fan rotations, and I did find one running in reverse. The wires were reversed at the factory!
When I topped my SS overflow tank to the top, it tends to burp a bit in high heat. I now keep it about 1/2 to 2/3 full when cool and it does not seem to overflow any more.
You might also be sure your pressure cap is correct and lifts only at the correct temp.
StuM
Old 07-05-2003, 06:10 PM
gsharapa's Avatar
Four things I'd suggest:
1. Make sure all the air is out of the system. Let it run with the cap off for awhile to burp out the air. The coolent should be high in the expansion tank.
2. Make sure you have a good expansion tank cap. 16 or higher lb cap.
3. Run the overflow line from the expansion tank to the bottom of the overflow tank. Then run the line off the top of the overflow tank down to exit under the car. When the engine gets hot and the fluid expands it will go in the tank but draw back when needed with the line at the bottom of the overflow tank!!!
4. Put a 50/50 mix of distilled water and anti freeze in it. Also add a can of wetter and this will help keep it cool......
Gary
CAV GT40
Display Modes
HTML code is On
