February 2026
Old 08-15-2003, 01:45 PM
Cobra Make, Engine: CSX4402
Default Engine casting number/ serial number
Where do you find the engine block casting number and/or serial number.
I believe my 351C 4V has the following number:
D2AE-CA which when doing a bit of hunting suggest 72 4 bolt (I know it is 4 bolt main) but Cobra Jet version.
I am trying to determine the 'origin' of this engine block.
thanks
Old 08-16-2003, 05:53 AM
Woodz428's Avatar
Arrow
The casting # is along the pan rail above the starter location. The # you posted is for both a regular engine as well as the CJ (all '72-'74). If the pan isn't off it may only be 2 bolt mains, the Cleveland blocks were all cast with 4 bolt ability but the main caps were different (as well as the finish machine work) on the 4 bolt block. The CJ name was dropped from the engine after '71 and was just referred to as the 4V, they came originally with a cast iron intake that used a spreadbore carb.
WDZ
