Old 08-26-2003, 07:44 PM
Default AMP Gauge Needle Pointing in Wrong Direction
I replaced my alternator. The back of the alternator was close to the engine block so I got some very slight sporadic arching when the engine was running. I quickly turned off the engine and fixed the problem. I noticed now that the needle on my amp gauge now points straight down instead of straight up (reverse where it should be). The needle moves when the engine is running – it is just moving in the down position (again, reverse where it should be).
Question: Did I fry the amp gauge or something else (starter solenoid? Capacitor?) when the alternator was arching against the engine block?
By the way – took the car out for a drive – everything else seems to be working correctly.
Thanks!
Old 08-26-2003, 08:04 PM
KobraKarl's Avatar
One wire alternator?
Old 08-26-2003, 08:25 PM
petek's Avatar
I can't imagine a way of frying an ammeter and get the results that I think you are saying you are getting. Are you saying the ammeter is reading a discharge condition while the engine is running?
Pete K.
Who is John Galt?
Old 08-27-2003, 04:24 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
probably pegged the meter and now the airpack is out of spec. Try another meter.
It is not uncommon for a meter to get damaged if it is a path for large currents that can be found with a short to ground condition.
Just my $0.02
Old 08-27-2003, 02:54 PM
Thanks.
Basically the gauge reads 0 at the 12 o'clock position and +/- 60 amps at the 3:30 and 10:30 position. The needle points at the 6 o'clock position. When teh car is running I see the needle flicker a bit showing that the alternater is charging, but flickering from the 6 o'clock position. Should be at the 12 o'clock position.
Old 08-27-2003, 04:24 PM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
My SW gauge was wired backwards from the factory. Go figure . I suspect you damaged the voltage regulator when it shorted out.
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 08-27-2003, 04:40 PM
RallySnake's Avatar
Steve,
Sounds like the needle has twisted on the shaft. Is the gauge new enough to be under warrenty? You will have to get a new one or take it apart to twist the needle back to the starting position. This is NOT easy.
The important question is, did you damage the alternator? Put a voltmeter on the two terminals of the battery. With the engine off, it should be at about 12.5 volts.
Have someone start the car. It should drop to 8 or 10 volts while cranking and then jump up to 14.5 once it starts.
If it's above 14 and below 15 volts while running, your alternator is OK. If not, save yourself a lot of greif and get it fixed. Shorting out like that may have damaged the voltage regulator or the diodes. You can run on the battery for days with a damaged alternator. You will not know it's bad unless you test it or the car's engine quits on the road. This is not a fun thing. Been there, done that!
Paul
