08-27-2003, 04:40 PM
CA
Steve,
Sounds like the needle has twisted on the shaft. Is the gauge new enough to be under warrenty? You will have to get a new one or take it apart to twist the needle back to the starting position. This is NOT easy.
The important question is, did you damage the alternator? Put a voltmeter on the two terminals of the battery. With the engine off, it should be at about 12.5 volts.
Have someone start the car. It should drop to 8 or 10 volts while cranking and then jump up to 14.5 once it starts.
If it's above 14 and below 15 volts while running, your alternator is OK. If not, save yourself a lot of greif and get it fixed. Shorting out like that may have damaged the voltage regulator or the diodes. You can run on the battery for days with a damaged alternator. You will not know it's bad unless you test it or the car's engine quits on the road. This is not a fun thing. Been there, done that!
Paul
