Old 09-09-2003, 06:43 PM
Question Resistor size for deleting solenoids
I am installing a 93 5.0 and want to delete the various solenoids that have no use in this application.
The problem is that when disconected they will throw a code and make diognostic routines invalid.
I understand that resistors can be installed but I dont know what ohm rating to install. HELP
jerry
Old 09-09-2003, 08:05 PM
wizard's Avatar
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
If you have access to the original solenoids and an ohm meter, you can measure and should be able to substitute accordingly since they are DC activated. I would also think that + or - 5% would also be acceptable. This is more of an educated guess though but should get you close enough. Good luck!
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
Old 09-09-2003, 08:18 PM
wizard's Avatar
P.S. Once you get the Ohm reading, divide that into twelve. This will give you amps. Multiply amps times 12 and you will get Watts. Make sure the watt rating on the resistor exceeds this number.
eg Ohm reading is 72.
12/72 = .16666
.16666 * 12 = 1.999 (2)
In this case you would want at a minimum of a 2 watt rated resistor. But to be on the safe side I would double the 2 watts to 4.
Watt ratings on resistors relates to how well they can disapate heat.
Old 09-09-2003, 10:46 PM
Hmmmm,,,,,and what function did these solenoids originally have?
Ernie
Old 09-10-2003, 08:46 AM
The purge valve and the thermactor dump valves
jerry
Old 09-10-2003, 08:58 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
You can replace the TAD, TAB, EGR, and Cannister purge solenoids with 10K ohm, 1/2 watt resistors.
Pete
Old 09-10-2003, 06:01 PM
Thank you
jerry
