Old 09-20-2003, 10:26 PM
Default 351 cleveland
Two questions:
Ford built an experimental 3-2's manifold for the 351C, but I can not find one anywhere?!
What do I need to do to keep this 9:1 compression 351C from getting hot in my 32 coupe? (I detuned this so I can enjoy using regular)
Old 09-21-2003, 04:27 AM
Lightbulb
try Ford Power parts. I think they are still in C.A. I have seen some very rare stuff in their used parts store. This was a very long time ago.
Steven Rau
All my ex's live in Texas
Old 09-21-2003, 04:47 PM
Thanks a lot for the info. I'll keep trying until one turns up. It's good to know somebody else is aware of a tri-power set up for the cleveland.
Thanks again!
Old 09-22-2003, 02:34 PM
tim tim is offline
Cobra Make, Engine: Everett-Morrison, Boss 351 w/ TKO 5 speed, 94 vette suspension
I hope you have deep pockets? The last one that I saw went for around $2000.00, and that was just the intake. As for running hot, how much radiator do you have?
Tim
Old 09-22-2003, 03:36 PM
It's standard dimensions for the '32 but with 4 deep. Don't know the actual capicity or dimensions. I thought about a different water pump, but don't know where to find one that has the right pressure and will be flat enough to fit.
Thanks for the reply--$2000 is a lot of money, but I'll have to cross that bridge when and if I find one.
JB
Old 09-22-2003, 03:53 PM
cobrajeff's Avatar
Default Switched from 3-2's to 4-2's
....and I thought I got a bunch of money for my 351C 3-deuce set-up at $800 - but, that was a lonnggg time ago.
Even had a very rare "Group 2" Cougar air cleaner (looks like an oblong Cobra cast aluminum air cleaner, except had a Cougar cat instead of COBRA lettering) that I had modified to match the carb spacing (351C 3 deuce spacing is like Mopar 3 deuce, not like FE Ford).
They are rare - haven't seen any for sale in years. Have seen maybe a half-dozen sets over the years - mostly in the Detroit area.
Good luck searching.
Jeff
CobraJeff
ERA P 202
Old 09-22-2003, 04:10 PM
Thanks for the reply.
Old 09-22-2003, 04:19 PM
Junket's Avatar
Cobra Make, Engine: shell valley
Just curious was the 3-2's for the 4 bl. heads?
Ken
Talent is your head in communication with your balls.
Old 09-23-2003, 09:03 AM
cobrajeff's Avatar
Default Cleveland 3-deuces for 4V heads
The Cleveland 3-deuce set-up, like most Cleveland performance parts of the era, was designed for 4-barrel heads only.
The 3-2 set-up was originally designed for a 366cid version of the Cleveland engine that never made it into production vehicles.
Here is what the set-up looked like on my Pantera:
The tri-power looked great, and ran very well, but I still couldn't resist putting FOUR carburetors up there instead of three.
Here's what it looked like from the interior of the Pantera:
That car was a lot of fun - the Webers made a lot more noise (than they do in a Cobra) positioned right behind your head. When you stomped the throttle, it sounded like that Cleveland was sucking in the entire Earth's atmosphere! What a sound!
Jeff
CobraJeff
ERA P 202
Old 09-23-2003, 09:20 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Do the head gasket mod, run a high volume water pump, set your T-Stat at a break temp of 195, run a five row aluminum radiator ( a big one ) with "wetter" additive and a 16 inch fan that pushes 2700 or more CFM.
You should be able to run in the desert with this setup.
Just my $0.02
