SUPPORT OUR SPONSOR
Old 10-09-2003, 07:51 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Question Fluid Evacuation Pump - Manual
Hi Guys:
I would like to get a fluid evacuation pump that I can use to drain my brake lines and clutch master cylinder lines. I have seen two or three types, one being a tall unit that can do triple duty as an oil, trannie, rearend and with optional hoses brake pump.
The others are smaller and are suitable only for brake fluid extraction.
These all use either a vacuum chamber or a hand caliper to cause vacuum.
There is so much experience on this board I was hoping to have you all point me in the right direction.
All ears....
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Old 10-09-2003, 10:23 AM
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
I purchased a MightyVac vacuum/pressure pump that I have used on brakes and an automatic transmission. It has a pressure/vacuum gauge that is helpful. The pump has worked well for the things that I have done but I had to build a bigger container for withdrawing trans fluid out through the dipstick.
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
Old 10-09-2003, 01:13 PM
Roscoe's Avatar
I have one....her name is Barbara....
Sorry,
Roscoe
Roscoe
Old 10-09-2003, 01:31 PM
Clois Harlan's Avatar
Roscoe,
You may wish you had bought a Mighty Vac if "Barbara" reads this.
REDC'
I have the Mighty Vac and I have used it for my clutch and brakes as well as siphoning gas from my barrel to my fuel cell (I change hoses of course).
I haven't had an occassion to add or subtract fluid from my trans or diff but I wouldn't hesitate to use the Mighty Vac. If you do use your Might Vac to bleed your Hyd clutch get back on line I found an easier and quicker way using the Mighty Vac.
Good Luck,
Clois
"Let's roll"
"Be part of Something Good
Old 10-09-2003, 02:13 PM
REDSC400's Avatar
Roscoe:
You gotta' send Barb over to help then....
Here's how'd it'ad go....
"ok Barb, down..... slowly...... ... Stop."
"Ok Barb, Up."
"Ok Barb, down..... slowly...... ... Stop."
Hummm..... Sounds like a sex ed techniques class..
No Premature Fluid Evacuation.....
So, it looks like I need to find a MightyVac?
Art in CT
Old 10-10-2003, 07:58 AM
jhaynie's Avatar
I think a company in the back of HUSTLER used to sell them. Check there.
It that doesn't work JC Whitney had them for around 70 bucks with all types of adapters.
Old 10-10-2003, 08:47 AM
Roscoe,
Are you in trouble now or what? My wife still reminds me of the little reference I made to her being more quailfied as a brake bleeder than I was. Now, I have the Mighty Vac and I have to do my own bleeding and pumping. I hate that.
Clois
"Let's roll"
HTML code is On
