SUPPORT OUR SPONSOR
February 2026
Old 01-04-2004, 09:48 AM
Default Intake gasket - to cork or not?
I'm doing a fresh intake install tomorrow (Victor Jr. w/ Vic Jr heads) and wondered about using the cork end pieces that come with the Fel Pro 1262 gasket set. The last time I did this (2 years back) I used them in combination with plenty of Permatex Blue. Should I skip them this time and just use Permatex?
Thanks
Scott, SPF#1230
Old 01-04-2004, 10:15 AM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Use them
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 01-06-2004, 09:22 AM
Mr.Fixit's Avatar
DO NOT USE THEM
just use silicone or "the right stuff" silicone. Cork can hold the intake too high and cause intake leaks, they can squeeze out, they can split while torquing down the manifold.
Old 01-06-2004, 11:36 AM
Cobra Make, Engine: 427SC Unique
Do not use the cork.
There is not 1 good reason to use it , however, there are 10 why not.
Brent
Old 01-06-2004, 02:32 PM
DAVID GAGNARD's Avatar
The first thing I do when opening a new gasket set is throw the intake gaskets away after tearing them in two,do not want anyone to have any trouble with them.....
Have always used the blue RVT or RTV whichever it is called,clean the block ridge with some paint thinner on a rag and do the same with the bottom of the intake on both ends,let dry,them put a bead of RVT about the size of a pencil or a little larger along the block ridge,let dry a few minutes till "tacky",then carefully install intake,let dry completely and with a razor blade trim off bead flush with intake and engine,makes for a clean,good looking seal,to this date I have never had on leak or "blow out"....
David
DAVID GAGNARD
Old 01-06-2004, 04:36 PM
Thanks gents. The first time I did this I used the cork end gaskets. Last night, I installed the intake without them. I just used plenty of RTV black in the front, back, and around the water holes. Let's hope this last longer than 2 years!
Thanks again.
Scott, SPF#1230
HTML code is On
