SUPPORT OUR SPONSOR
December 2025
Old 02-26-2004, 07:28 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default 351 Cleveland head ID
Hi all. I'm finally getting around to documenting all my engine info. Can anyone tell me where the casting numbers are on the 351c heads? Do I need to pull the valve covers?
Thanks
Greg
Old 02-26-2004, 08:16 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Yes you need to pull the covers. The numbers are cast in the top of the head.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-26-2004, 08:59 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
I think the number is cast on the underside of the intake ports.Since there is little difference between most 2v heads (as well as M heads), if you are trying to determine if it is a 2v or 4v head the early 2v heads and the 4v heads have either a 2 or 4 cast in the upper corner between the intake flange and the valve cover lip.
WDZ
Old 02-27-2004, 05:10 AM
Cobra Make, Engine: Unique 427 SC on order, 351c4v and top loader for power. And did I say that it will be Orange with white stripes?
Woodz428 is correct about the casting numbers being underneath the intake ports. You will have to pull the heads to read them
Kelly P. Mullins
Old 02-27-2004, 08:09 AM
Club Cobra Member
Thanks guys. I'll pull a valve cover first and see what I can learn.
Greg
Old 02-28-2004, 05:16 PM
Club Cobra Member
Pulled the valve cover - no casting numbers. But the "4" is there at the top corners of the heads and the "4" shows up in pictures of 4v heads in various books. I guess I have 4v heads!!!!
My cast iron intake casting number is "DOAE 9425-L" and is a 4v intake, so I can conclude I have 4v heads.
Thanks all.
Greg
HTML code is On
