02-29-2004, 02:34 PM
jackl
Hi,
Because of the low clearance and sidepipes, it is always a little more work to get my car up on jack stands. I usually drive it up on two-by-fours and then use a low profile jack before using a bigger jack and so on. This whole process would be a lot easier with a narrow, low profile jack. To get in between the exhaust and the front or rear wheel, the jack can be no more than five inches wide. And the most convenient would be lift from four inches to 20. It would also be great to be able to lower the car slowly. Some jacks do while others offer a freefall. I have six jacks in the garage including my latest additon from Craftsmen that goes from 4 inches to 20 in two lifts and only weighs about 35 pounds. But (!) it is too wide. Question: can anybody recommend a jack or supplier or have other brilliant ideas on how to do this short of a lift? Thanks.
Irv
ERA 427
02-29-2004, 02:55 PM
Just how low is your car?
I jack up the front with a standard floor jack by going in diagonally just in front of the front tire. You can pick up the front crossmember that way.
In the rear, go straight in from the back with the jack centered. You can jack on the subframe or the differential casting.
02-29-2004, 03:05 PM
Irv,
I use a small scissor jack from a Honda (cheap at the recycle yard). Put it under one side of your frame to jack the car up just enough to get a heavy-duty floor jack in from the rear. Goes right under your sidepipe and wallah. Easy..., takes 30 seconds or less. Try it.
Duane
02-29-2004, 05:12 PM
more on jacks
Car is LOW. I have less than four inch clearance under the car. Three inches or less under the exhaust. And, I have a scissor jack, too. Just hoping to find an easier way of doing this. A narrow, low profile jack that can lift from less than four inches to about 20 or more would just make my garage life easier.
Irv
03-01-2004, 07:40 AM
Harbor freight has an aluminum jack the saddle starts at 3.5" high and goes to 17.5" the overall height is 6.1" high so I don't know if that would let you in far enuff.
03-01-2004, 07:59 AM
NJ
I've got one of those Harbor Freight jacks. Really nice and only weighs around 37 pounds. Six pumps for full extension.
Matter of fact they are on sale now for 89.95
http://www.harborfreight.com/
Roscoe
Roscoe
03-01-2004, 07:53 PM
Hey Roscoe, nice pic. When I scroll up and down on it I swear the handle is pumping?! If you join the Harbor Freight Inside Track club you get even better deals on the stuff. Some of it's cheepo chinese, some is good stuff.
03-02-2004, 10:36 AM
more on jacks
Thanks for the tips. The Harborfreight jack looks good and is a great deal. Problem for me is that jack is too wide too. I got a space of about five inches in width through which I need to slide the jack -- whether behind the front wheels or in front of rear wheels. I have one jack like that already that I found in a local auto parts store for $19.95 - but it only lifts to about 15 inches. So I will continue my search for that perfect jack -- five inches wide, low profile (four inches) and lift of 20 inches -- and with controllable drop - so I can ease the car down. My cheap jack does that well too. My other jacks are great -- but for this car they are just too wide.
Irv
03-02-2004, 12:15 PM
Member of the north
Cobra Make, Engine: A Cobra
I use a jack from a PT.
Chrysler made a low profile jack that is great for my car.
My Wife it a little miffed over the jack missing from the PT, but you have to have your priorities.
Just a thought.
03-02-2004, 03:01 PM
WA
Have you tried Rhino Ramps or a facimile from Griots Garage? Not a jack, but works well as long as you use a spotter. Raises the car up far enough to change oil etc. I used them on my wife's Miata 3-4 years ago and drove right off the end of the Rhino Ramp. Duhhh! Good thing it was not a big deal to use a floor jack to get the car off the ramp. And....Good thing no one was watching too! I haven't shared this story with many car guys to date.
03-02-2004, 08:08 PM
WA
Groits also offers a low profile jack .It looks like it would only be an inch or so high but it is a little pricy.
I have the same problem.I start with a sizors jack under the tortion bar bearing, get a little heigth then use a floor jack under the center frame. same process in reverse coming down.
Mike H
07-17-2012, 08:25 PM
Senior CC Premier Member
At home, I use a Kwick-Lift which brings it up about 20". Away from home, check out Race Ramps or someone similar. But that's if you have a rig to haul them to wherever you are going. On the road and in a pinch, low-profile bottle jack in the trunk, a knock-off hammer, safety wire and a wire spinner tool among other things that may come in handy. My 2 cents.....
07-17-2012, 10:54 PM
Full Blown Member
AC Hydraulics has a low profile jack that is long and strong.
Not a bad tool to spend more on.
rodneym
07-18-2012, 05:44 PM
I have a jack from a newer Trans Am. It is really low. The collapsed height is just a bit over 2".
07-18-2012, 05:51 PM
MO
Cobra Make, Engine: Hurricane - FE
Norco Low Profile
Take a look at the Norco 71233A jack
I use one and come straight in from the front, under the oil cooler and pick up by the front cross member.
In the rear, I go in diagonally to reach the rear frame cross brace and lift it.
The trick is the low profile lifting arm with a little extra reach the normal jacks don't give you.
Paul
07-18-2012, 07:48 PM
Ca.
I know that this is a resurected 8 year old thread but FYI, this is the jack that I use. It will slide between the front wheel and side pipe and grab the frame. At least on my Classic Roadster anyway. I can jack the whole side of the car up from there if I want.
Aluminum Floor Jack - 1.5 Ton Aluminum Racing Jack
Terry
