03-22-2004, 10:01 PM
I inquired recently about using Linex the bed liner product. I got scared off by the $3000 estimate for labor and materials.
03-23-2004, 06:16 AM
Originally posted by Jetlaag
How does one measure the moisture content in the concrete of a garage floor??
Would you tape down a piece of plastic on a section of the floor?
If so how do you measure the content of the moisture??
Just curious as I am ready to paint my garage floor and am looking for any ideas for a cool paint scheme on the walls of the garage.
Jetlaag
Jetlaag - you are right on the money. ASTM standard D4263 (commonly called the "mat test") outlines a moisture testing procedure that calls for taping an 18" x 18" piece of plastic onto the floor- sealed with duct tape all around. After 18 hours, look for presence of condensation under the plastic - if none is visible you are OK. It is basically a pass/fail test. Where it gets fuzzy is if there is no moisture present, but the concrete is darkened under the plastic.
To measure exact content, you need fairly sophisticated equipment for the average homeowner - I would suggest you try the "mat test" first. Here is a link to more exotic equipment if you wish....
http://www.constructionbook.com/xq/A...x/default2.htm
I am out of country until Sunday. If you email me, I can forward the ASTM standard to you upon my return.
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
03-24-2004, 03:44 PM
Devcon Coating Products
At an Industrial Products briefing by Applied Industrial Technologies , the coatings made by Devcon, which can be used on concrete, were only 1 of 2 vendors listed in their catalog, the other being Loctite. AIP is a major nationwide supplier to
industry with sales of $1.9 billion
www.devcon.com
Epoxy Systems
Devcon Engineering Coatings epoxy systems are 100% solids coatings for rebuilding worn/damaged substrates and sealing/protecting new or repaired surfaces. Ideal for guarding against corrosion, erosion, chemical attack, abrasion, and wear, Devcon epoxy systems protect concrete, steel, and other substrates, and cure to smooth, seamless finishes that are potentially stronger and more durable than the original substrates.
_Name
Description
ARL 6000
A 100% solids novolac epoxy lining which provides superior protection of concrete, metal, and FRP surfaces against severe chemicals
CC 4000
A brushable epoxy coating for rebuilding worn areas less than 1/16" deep or protecting new equipment
CC 4000 Thinner
Consult Factory
CP 2000
A 3-component formulation for repairing and patching severely damaged or pitted concrete
CR 5000
A high-performance, high-density glass flake-filled sprayable epoxy coating
CRL 7000
A 2-component highly cross-linked oxirane polymer coating
CS 2000
A clear epoxy coating for priming, waterproofing, protecting, and sealing concrete, masonry, and ceramic surfaces
CT 3000
A trowelable, ceramic-filled epoxy repair system
CW 3300
A high-performance epoxy wearing compound with small and large high-alumina ceramic beads and silicon carbide chips
SL 1300
A 2-component, 100% solids epoxy coating for resurfacing, sealing, and protecting concrete floors.
Z9411 Primer
Z9411 is a 2-component, 100% solids epoxy primer that provides excellent adhesion to concrete, steel, brick, and most manhole construction materials.
Anti-slip additives are available
03-27-2004, 01:22 PM
Mi
Well, I am in my normal state of total confusion! Dave, what did you go with?
New shop is almost ready for some coating on the floor, but I still haven't made my decision.
How about we have a DV paint party at this years Fling?
Ed "DV" Combs...doesn't this headache ever go away?
03-28-2004, 07:36 AM
More Choices
Other choices:
www.rustoleum.com
www.permacrete.com
www.precisionepoxy.com
Does anyone know the product ( s ) used by the major NASCAR race shops ?
03-28-2004, 08:05 AM
SC
Cobra Make, Engine: Superformance / 427 SO
One of the homes I looked at in SC had their garage floor coated. It looked great and I asked him how long ago he had it done. He said SEVEN years ago (and he showed me the reciept). It looked brand new. It's very close to the product a buddy of mine in Chicago had done a few years back and it has also held up fine (Durabond). Heck, I may buy that guys house just because of the garage!
The company he used is called Premier Garage ( www.Theultimategarage.com). They also do some pretty nice custom cabinets (the home owner had some of those as well, along with a nice built in work bench). Apparantly, these are small franchises all over the country. Check the website and there may be one near you. They do a solid color application, or they also offer a "simulated granite" (which this guy had) that looks awsome. Easy to maintain too. He said all he does is broom it out and every once in awhile he mops it. he said he's spilled gasoline and oil on it many times and never had a problem. Just wiped off with a paper towell or rag. I also noticed that he owned a floor jack and I asked about damage from that. He walked over and started rolling it around, back and forth, and then he jumped up and down on it. It didn't leave a mark. Then he took a 2 by 4 that was propped up in a corner (about 4ft long) and started beating it into the floor! Not a scratch could be found.
..........I was sold.
04-02-2004, 12:11 PM
OH
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
DV,
I went with the Wonder Paint. The stuff just arrived yesterday.
So far, they have been great to work with, answering questions, etc.. I'm excited to put this stuff down, and see how it looks.
If you want to see the raw materials, or want more info or a contact, lemme know. Hoping to get started when the weather breaks. (whenever that may be...  )
~Dave
PS> You help me with mine, I'll help you with yours!  I need to come over there and check out that new shop, anyway.
04-02-2004, 03:28 PM
Mi
Dave, you have a deal!
I'll even help scrub your old concrete!
You do know the shop I am talking about is in Pentwater Meechigan don't you?
Tell me when, I'll certainly try to be there, that is if I'm not in Meechigan!
DV...
04-02-2004, 07:20 PM
UT
Cobra Make, Engine: "ORIGINAL" Kirkham #302-Stainless Steel Chassis w/Billet suspension -427 Shelby Aluminum block stroker 495ci by Kinetics Race Engines
SnakeBit: you may want to ask him to leave some brake fluid and/or gas, and brake cleaner, for a real test....If it holds up then it could last over time if the proper prep is done
Jorgen Moller
Founder/Inventor
RaceDeck Garage Flooring
800-457-0174
All CC Members Get Discounts
[b] http://www.racedeck.com
Life Member of the Bonneville 200 mph Club
05' Ford GT- Retune , Pulley & Exhaust 650+hp
Superformance GT40 MK2
63.5 Falcon Sprint ' Voodoo Falcon' GT350R powered
93 Ford Escort RS Cosworth FIA Rally Car
04-02-2004, 08:18 PM
Cobra Make, Engine: KMP
Jorgen:
Any discounts for Club Cobra members?
Lew
I'm no expert.
04-03-2004, 11:15 AM
OR
Cobra Make, Engine: UM 289 FIA, 396W stroker
Originally posted by Lew Ledyard
Jorgen:
I second the question!
While Racedeck sounds nice, I have a sinking feeling it's well out of my price range- mostly because people continually ask the price in these forums... and get zero response.
Enquiring minds wanna know!
Russ Rainforth
04-03-2004, 11:44 AM
NASCAR Garage
I have inquired with DEI and Rousch Racing as to the floor coating used in their NASCAR race shops. Will post the response
Above company is located in Georgia, mentions their product is used in the motorsports industry without any specfic race shop mentioned
All the race shop pictures appear to have a coated surface, have not seen any using tiles of any type ?
04-03-2004, 12:20 PM
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
My understanding is that Racedeck runs about $4 a sq foot, but I don't know if thats installed or materials.
04-03-2004, 12:37 PM
CO
Cobra Make, Engine: Former owner of BDR 127......
Racedeck....
For my 23x19 two car garage, they wanted about $1200 for the diamond-style panels. This is product only. Labor would be yours truly, although the dealer in So Cal will do installs as well, if you wanted them to.
- Snak Iyz
04-03-2004, 02:24 PM
UT
The cost depends on what style ( 4 styles and 14 colors) and what qaunity you are looking at ( over 500 feet puts you at a better price break. We have dealers throughout the country or you can call me direct...You are looking at a price of anywhere of $2.49 to $2.99 with CC discounts..
jmoller@snaplock.com and I will make sure that you get your CC discount...
Jorgen Moller
Founder/Inventor
800-457-0174
04-03-2004, 02:34 PM
Ouch Ouch Hot Sand
I have found 2 race deck dealers in the SE region that sell the Race Deck at $2.49 a sguare foot, one plus shipping, the other shipping included. One will sell any quanitity, the other any but prefers at least 2 to 3 cases. I am "not" posting their info but if anyone would like it feel free to contact me.
04-03-2004, 03:11 PM
Shhh....Do I hear a Racedeck buyers club forming?
04-05-2004, 02:23 PM
Jorgen:
If the CC discount is right, I am ready to buy Racedeck flooring to cover 55'X27'.
Lew
I'm no expert.
04-06-2004, 01:15 PM
OH
DV,
Oops!  I thought we were talking about your new shop behind your old shop! But, what the hay, Meeeechigan it is.
Which brings me to my next question.......what is this shop for? I need to see them BOTH!
~Dave
04-06-2004, 01:19 PM
Mi
Dave, the new shop in Meechigan will be my retirement "show place". Or, when Diane finds out  about more custom cars it may be my newest living quarters!
Hope you're laying the new finish down Today is a beUtifull day!
DV
