SUPPORT OUR SPONSOR
Old 06-25-2010, 06:02 PM
Fantastic, I needed some collector gaskets!!!!! Home run, this should be documented on SCOF also!!
Originally Posted by ekrupa2 View Post
Had a similar backfire on deceleration...collector gaskets completely blown. So far I have been extremely happy with these...www.remflex.com.
Will switch my copper header gaskets with these someday too.
Old 06-25-2010, 04:32 PM
Rick Parker's Avatar
This thread is 6 years old.
Rick
Old 06-16-2012, 03:40 PM
Send a message via MSN to CowtownCobra
More like 8 now, but a backfire is timeless
Old 06-16-2012, 02:52 PM
BAsque1's Avatar
have noticed also the right side pipe poping from 1st to 2nd gear not while slowing down, could it be the side pipe-header gasket? they are fairly new... they are a pain in th rear to change no room change opinions there...sigh
Old 06-16-2012, 03:43 PM
That doesn't sound like an exhaust leak.
Old 07-06-2012, 07:42 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by CowtownCobra View Post
Car is running great, but recently it has developed a backfire on the left side (none from the right). Letting off big time leads to a big pop, while normal slow downs lead to mutiple smaller pops. It didn't use to do this. What do I check for, fouled plug, bad plug wire, or what. I'm clueless...
Ideas?
I developed the same problem very suddenly yesterday, except the popping was coming from the passenger's side. I had been swapping out the valve cover gaskets right before the problem began...when I got it back home I found that somehow I had "dislodged" the distributor cap and it was "cocked" slightly rearward....naturally, the sparks were flying all over the place. Once I had it secured again the problem went away.
Check yours...it doesn't need to be off by much.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
Old 07-29-2012, 08:11 PM
Cobra Make, Engine: ERA#134 427 Ctr oiler 2x4's
I've had this problem intermittently on the right side. Also, wouldn't start sometimes. Pulled the distributor cap and yee gods! Corrosion all over the place! It's a wonder it ran at all.
Old 08-05-2012, 01:42 PM
BAsque1's Avatar
This should become a Sticky, it is a timeless problem. The first diagnosis of a leak between the header and the dead was dead on. It is fixed now no more side backfires.
Lou
Display Modes
HTML code is On
