SUPPORT OUR SPONSOR
Old 04-04-2004, 05:58 AM
Rick Parker's Avatar
Sometimes the fan will begin to rub on the alternator housing if it is not sandwiched tight enough between the pully and spacer. Check the tightness of this with a box end wrench and a hex wrench or hex socket (best). Otherwise as mentioned check the front bearing.
You mentioned Gilmer belt, do you mean "toothed" belt ? If so, the pulleys need to be aligned perfectly or there will be l harmonics transmited by irregular tooth engagement.
Rick
Rick
HTML code is On
