Old 04-19-2004, 05:09 AM
Cobra Make, Engine: ffr2497--302efi
Default i few small block ford questions--.
hello everyone,
i have a few more questions because i always get the right
answer.
1.right side engine mount hitting header--what to do?
2.what do you set your base timing at?
3.what spark plugs to use?-302 fuel injected-edelbrock
performer aluminum heads.
thank you for your help.
dave
i will have one soon!
i have one now.
Old 04-19-2004, 08:59 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Just an opinion, but, use a diegrinder and do a smooth cut on the motor mount to allow clearance. Paint the bare metal. If the headers have nothing other than paint on them, you can dimple the area A LITTLE.
Set the timing at 4 - 12 degrees BTDC to start. ( 4 BTDC is my personal choice just in case )
Plugs are a fit and try item for me. Check with the book and go from there.
Just a thought.
Old 04-19-2004, 09:21 AM
There's a small chance you could use up some bolt clearance, loosen the motor mount and force it away from the header as you re-tighten it.
