SUPPORT OUR SPONSOR
Old 05-04-2004, 09:43 AM
Zoom This's Avatar
Default Best timing setup??
I need some help from the forum on setting up my timing for best performance on my 418 stroker.
What is the optimum setting for initial advance, full advance and at what rpm should full advance be in by? I have an MSD 6AL with the spring kit and limiters ready to go. Car has 10.25:1 compression, .570/.586 dual pattern cam, Edelbrock Victor Jr. heads and an 850 Holley.
Should I recurve the distributor at 20 degrees initial, with full advance of 38 degrees by 2800 rpm? I am not quite sure how the timing should be designed for getting optimum performance - horsepower and torque - from the mighty 418. Thanks for you help.
Bill
Old 05-04-2004, 07:34 PM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
I also have a 418 and I set my initial at 10 degrees with 25 in the distributor. I kept the heavy silver springs that were in the distributor for the fact that when I used a light silver and a light blue the timing advance started about 1300 rpm. I did not want any centrifigal advance at that rpm for my emissions test. I also have an MSD 6L with a billet distributor. The engine seems to REALLY like that setup!
Terry
Old 05-04-2004, 10:13 PM
I retarded my base timing to 10 from 14 in an effort to LOOSE some horse power.
,,,,,,,not much success, maybe I'll try some really quiet mufflers next.
HTML code is On
