SUPPORT OUR SPONSOR
February 2026
Old 05-12-2004, 12:53 PM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Default MSD Box Noise?
I have a MSD 6AL box and the other day when I was driving I heard what sounded like a quiet electric hum coming from the box. It almost sounded like a hum you would get with an electric fuel pump (I have a mechanical pump so that wasn't it ). I only hear it periodically and the car is running fine.
Is this normal? Has anyone else heard this?
Replica is not a dirty word.
Old 05-12-2004, 01:31 PM
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Chaplin,
Its normal. The coils and caps inside vibrate as magnetic fields are induced in them. If you listen closely you may even hear a tick each time it fires a plug. Drive faster so you don't hear it.
Old 05-12-2004, 10:23 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Chappie
Jims right--never noticed it on my other car but on this one I would hear it and it was driving me nuts thinking something was wrong. Then by accident I happened to hear it when I was under the hood and had the engine running at about 12-1500 rpm.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 05-13-2004, 05:01 AM
Chaplin,
You can hear a little humm over the sidepipes? GEEEESH! I can't even hear my electric fan over mine.
John
Old 05-13-2004, 06:47 AM
Chaplin's Avatar
Jim/Gary-
Thanks guys. Good to know nothing's wrong.
John- I can't hear much over the pipes. The only reason I can hear it is because it is mounted inside the car under the dashboard. And I've only heard it a couple times.
Old 05-13-2004, 08:02 AM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
A noisy MSD box in a Cobra?
Turn the radio up a little more.
TURK
OBAMA IN in 2012
Old 05-13-2004, 08:10 AM
Chaplin's Avatar
Turk,
I would but I don't drive the most accurately detailed 4000 to original specification since the demise of CSX 4027, and therefore, I do not have a radio.
Old 05-13-2004, 08:42 AM
Junket's Avatar
Cobra Make, Engine: shell valley
Chaplin I belive there was a thread on this about a year ago can't find it but the offending member (MSD Box) was sent to factory and was replaced might call MSD I have had several and mine don't sound like my fuel pump.
Ken
Talent is your head in communication with your balls.
Old 05-13-2004, 09:04 AM
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Originally posted by Chaplin
Turk,
HAHAHAHAHAHAHA
J.P.
Ohio Cobra Club
Token Gashole
Old 05-14-2004, 08:14 AM
Chaplin's Avatar
Junket-
Just to be safe, I called MSD and they said that it is normal for the box to make a slight humming noise and that it is nothing to worry about.
HTML code is On
