SUPPORT OUR SPONSOR
Old 05-22-2004, 04:33 PM
timsullivan's Avatar
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default Contemporary Brake Mst Cylinder ID?
I have an older Contemporary cobra ( CCX 3-3408) with a leaking master cylinder resevoir (sp?). It is a one piece cast unit consisting of both the brake and clutch master cylinders in one cast unit. The cover for it is rectangular shaped about 3.5 inches by about 2 inches. It has "made in the USA" cast into it with each protruding cylinder labeled "brake" and "clutch" cast into it. I have the hanging pedal assembly with the master cylinder mounted above the pedals and projecting into the engine compartment. Any idea what make or brand this master cylinder is? Thank you for any help you can give.
Old 05-22-2004, 04:55 PM
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
I have a brand new Contemporary Pedal Assembly that I never used. I haven't even unwraped the bubble wrap. If you are interested in purchasing let me know.
Thanks
Gary
Thanks
Gary
CAV GT40 Dealer
www.2gmotorsports.com
Old 05-23-2004, 10:12 AM
Located pedals and they are in good shape, but do not include master cylinders. From my contemporary manual the cylinder requirements are as follows:
Brake MC (Floor mounted) Girling 211530
Brake MC (Suspended) Girling 21-1178
Clutch MC Girling 211532 (requires custom spacer)
Thanks
Gary
CAV GT40 Dealer
Old 05-23-2004, 10:56 AM
Gary: Many thanks for this information. Looks like this will do it for me.
Old 05-23-2004, 12:18 PM
No luck. My master cylinder is a one piece, cast unit consisting of one resevior for both the brake and clutch. I suspect my Contemporary is an older one before they started using separate cylinders for the clutch and brakes. I have a newer construction manual and it too mentions separate part numbers for the brake and clutch cylinders, but my unit is combined. Looks like I'm 'outa luck here....
Old 05-23-2004, 09:22 PM
Cobra Make, Engine: HI-TECH 289 FIA
Sounds like a Chevy truck cylinder set. One casting with two bores and a common resevoir. Lot of guy used these. Don't have the number anymore but it was off a lite Chevy truck about 63-64 -65? vintage.
fiaroadster
Old 05-24-2004, 05:42 PM
Many thanks Rick. I'll see if I can hunt ones of these down.
Old 05-25-2004, 07:25 PM
Yep! That's the one. 1962 Chevy pickup with standard trans. Slightly different back flange but looks like it will fit perfectly with one, lower bolt hole redrill!
Display Modes
HTML code is On
