SUPPORT OUR SPONSOR
Old 06-04-2004, 09:05 PM
Cobra Make, Engine: B&B
Default plugging heater hose outlets
I'm using a stock water pump on a 351w, with no heater in the car what's the best way to block off the heater hose ports in the water pump, and is it still necessary to run the short 90 hose from the t-stat housing to the water pump?
Old 06-04-2004, 11:23 PM
Rick Parker's Avatar
There a couple of ways to do this. Ford has available black rubber caps that will fit over the heater hose outlet that you are not using, they are secured with a hose clamp or you can drill and tap the housing for an internal hex tapered pipe plug. Regarding the bypass hose, most people use it. It equalizes pressure buildup before the thermostat opens. If you elect to run without thermostat (not a good idea) you can delete the bypass hose and related connections.
Rick
Rick
Old 06-05-2004, 07:17 PM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Lightbulb
Thought this might help...
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
Old 06-05-2004, 10:08 PM
This is exactly what I needed to see and hear.
Thank you very much
Terry
HTML code is On
