SUPPORT OUR SPONSOR
Old 06-14-2004, 01:06 PM
rdorman's Avatar
Renegade Nuns on Wheels
Question Car cover inside out?????
Is there an outside and inside to these things? I bought one of those three layer all weather covers and was shocked how much water came through it. It would seem logical that there is an outside and a inside but how the heck can you tell the difference?
Any one else put one on inside out and have the same experience?
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 06-14-2004, 01:16 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Hmm, I don't own an outdoor cover but I'm under the impression that the outdoor covers are not intended to keep the water out. Rather, they're intended to allow a wet car to dry rather than trapping all the water under the cover. That is, I think they're supposed to be very breathable and they will allow water to pass freely from either direction.
Chris
Old 06-15-2004, 11:03 AM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Rick: The inside part of the car cover has the tag that says "Do not remove under penalty of law..." Rich
Old 06-15-2004, 11:13 AM
rdorman's Avatar
Darn it! I knew I shouldn't have smoked that tag.
So there is an inside and outside?
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 06-15-2004, 11:17 AM
RallySnake's Avatar
Rick,
They usually have "front" stencilled on the outside of the cover. I saw a display once of the technalon cover. It had a small piece of the special fabric sealed into the middle of a clear plastic bottle. The upper half was full of water, the lower half had air only. When you squeezed a bulb attached to the lower half, air bubbles would pass through the fabric and float to the top. Your car should remain dry.
I usually paint a big arrow or something on the outside of mine because it's sometimes hard to find the "front". The inside usually has the rougher unfinished edge of the fabric showing, too.
Paul
Old 06-15-2004, 11:26 AM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Dorman, It's a cover for God's sake... A COVER!!!!!!
Is this the same Rick Dorman who takes his car apart on a regular basis and then reassembles it?????
and I was going to have you help me with a carburetor install???
This may be a little too technical for you...
If you're reading TNORF on one end of the cover just flip it over...
Old 06-15-2004, 11:30 AM
rdorman's Avatar
LMAO, Al, I was thinking the same thing when I posted this thread. I can talk for hours about brake and chassis dynamics, but a car cover.......... forget about it!
A soon as I get the radiator project done (of course custom made everything), I think it is time for a little cover experimenting. Using the scientific method of course!
See you soon!
Rick
OhioCobraClub.com
LondonCobraShow.com
HTML code is On
