SUPPORT OUR SPONSOR
Old 08-01-2004, 08:12 AM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Sorry to bother all of you .I ended up swaping the supply and return lines .The fittinng out the back is common with the log ,Pressure gauge .the two under the regulater are return.Ended having a hose built with a tight 180° #10 hose end to run line along fuel log . Covered everything with heat sheilding and wire tied it up tight.The fitting at the gauge port (out the back) is SS #8 AN O-ring male to 3/8"npt female right angle.$55,Came from Ohio I hate small brass dangely fittings waiting to break,especially with gasoline.
Mike H
HTML code is On
