Old 08-03-2004, 05:34 PM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Thumbs up Superformance Harness mounting
Ok all you Superformance Owners,
I have a 2003 MK3 Superformance here on OZ, and am wanting to mount a 4 point harness.
Now the base points are fine but trying to locate and mount the above sholder locations points are a bit of a problem.
Im not sure if i mount to the roll bar ( or through ) if it is strong enough or crush resistant enough.
Or where there may be other points apart from adding a seperate bar between the two forward roll bars and mount there.
Or if it is safe enough to mount them to the bolt mount that attaches the third rear leg to the forward roll bars, this location seems to high.
Look forward to your help, Pics please.
Regards Garrett
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 08-03-2004, 05:43 PM
Karl Bebout's Avatar
Garrett, I've always heard that the mounting for the shoulder harness should be lower than the driver's shoulders to be most effective. Enzo, at Finish Line sells a real nice roll bar cross member.
Karlos
Old 08-03-2004, 05:57 PM
gsharapa's Avatar
If you check from under the car you will see where SPF has slit the fiberglass where you put the belt through and bolt it to the frame cross member behind the seat. The carpet has a small slit in it also but is hard to find. Frame is drilled already!
CAV GT40
Old 08-03-2004, 06:38 PM
Cobra Make, Engine: SPF #1019
Thumbs up
Gary is 100% right!
