SUPPORT OUR SPONSOR
Old 08-15-2004, 05:43 PM
Club Cobra Member
Cobra Make, Engine: Kirkham 482 ci alum block
Default What Bulb for rear lights?
Hey guys,
Couple of quick questions about the rear taillights I bought from Finishline. First, I must have misplaced the bulbs for the rear, are they the same as the ones used in the front turn signals? Second, the headlights and front turnsignal provide a ground wire, the rears do not. Do I attach a ground wire to the mounting screws and then to the chassis???
Thanks an advance
David
Old 08-16-2004, 04:03 AM
The rear bulb is an 1157. It may or may not match the front.
Ground the stud.
Old 08-16-2004, 07:35 AM
Club Cobra Member
Thank You strictlypersonl
David
Old 08-17-2004, 05:53 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
We use 2057. Same base as 1157, but brighter.
Nonconformist. Can't handle a real job.
Old 08-18-2004, 04:24 AM
According to the spec's listed at donsbulbs.com, the 1157 and 2057 are almost identical, except the 1157's parking filament is slightly brighter.
Old 08-18-2004, 05:12 AM
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
I put a 2057 on one side and an 1157 on the other and stood behind the car to note the difference---couldn't tell any difference! Got a second opinion from the wife---same thing.
When I said I wanted to be somebody, I probably should have been more specific...
Old 08-18-2004, 09:14 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
If you have Lucas assemblies, there are three loops to tie wires to: running or parking lights, Stop and/or turn and ground. The large brass looking loop is the ground. With the assembly face down and the ground loop at 12:00, the loop to the right is Stop/Turn.
All of the assemblies take 1157 bulb and have glass lenses. If you run 2057 bulbs on plastic lense cars, you may have a thermal event where the lense disorts or melts. But, if they are lucas and glass, the 2057 will give a marginally brighter ( viewed straigh in ) illumination.
Wire color codes are for the rear as follows: White is ground, Yellow is left stop/turn, brown is running/parking and green is right stop/turn.
HTML code is On
