SUPPORT OUR SPONSOR
Old 02-10-2005, 04:28 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default 302ci bolt sizes needed...please help
Need some sizes for bolts needed to finish up the 302ci, please help if you know......
bolts to hold crank pulley on?
bolts to hold water pump pulley on?
bolts for the mechanical fuel pump (2 bolts)?
bolts for the motor mounts in the block (2 on each side)?
bolts for the flywheel, are they 7/16" x 20 x 1" ?
bolts to hold oil pump in (2 bolts)?
Anyone who can help, please help.....
I'm not busy because I did it right the third time . . .I think!
Old 02-10-2005, 09:03 PM
Cobra Make, Engine: unique 427 302/300hp t/5
wish i could give all the correct sizes. but i can't remember what i do remember is that the flywheel is a metric sizes . you might want to go to ford dealer parts dept and maybe someone can help.
Old 02-11-2005, 07:31 AM
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Not sure of the sizes, with the exception of the flywheel bolts, I just pulled grade 5 stuff out of my bolt "bin" and ground length to fit.
Would think Summit Racing or CJ Pony parts could supply the correct stuff
http://www.cjponyparts.com/ContactUs.asp
- Dan
Old 02-11-2005, 07:48 AM
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
The flywheel bolts are special high strength bolts that you should only get from FORD or ARP. ARP also sells bolt kits for these engines that include intake, distributor, waterpump, timing cover, valve covers, oil pan...etc. Also there are different waterpumps that require different length bolts. I used an Edelbrock water pump and some of the bolts were too short. If this had come out 3 weeks ago I could have helped you on the oil pump - I just changed mine.
Get a Summit/Jegs catalog and look at the ARP bolt kits.
Old 02-11-2005, 06:21 PM
Rick Parker's Avatar
Here you go:
These are based on my recollection of my 289 assembly. I used & recommend ARP for EVERYTHING. DO NOT not use any generic bolts for ANY critical application.
1. Crank Pulley :3/8"NC x approx 1.25"
2. Water Pump Pulley: 5/16 NF x 1" (Too long they & they will foul the pump body)
3. Fuel Pump: 3/8"NC X approx 1.5"-1.75"
4. Motor Mounts: 7/16" NF x 1"
5. Flywheel: 7/16" NF x 1" or 1.25" (depending on flywheel or flexplate thickness).
6. Oil Pump: 3/8" NC X 1.25. ( recommend studs here, must be longer to allow for nut and washer.
Use 262 locktite sparingly.
Hope this helps
Rick
Rick
Old 02-12-2005, 07:01 AM
S_Beaudry's Avatar
Thanks for the help Rick.....
I am assuming that .....
NC = course thread
NF = fine thread
Am I right?
Old 02-12-2005, 08:21 AM
Yes.
Rick
Rick
HTML code is On
