SUPPORT OUR SPONSOR
February 2026
Old 04-17-2005, 06:56 PM
jams's Avatar
Cobra Make, Engine: B & B
Default Rich, lean or Timing
Hi,
Under heavy acceleration my car kicks out enough black exhaust that tells me it is not tuned correctly. Is that a rich condition, a lean condition, timing or some combination?
Could it just be a 4 barrell adjustment?
I may also need some adjustment guidance.
Thanks
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 04-17-2005, 07:36 PM
DAVID GAGNARD's Avatar
black smoke = rich condition,a lot of black smoke (like a diesel truck) very rich condition.................
DAVID GAGNARD
Old 04-17-2005, 08:35 PM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
Jams - if you have a Holley carb on that car, check / replace your power valve.. When they blow, the fuel mixture goes extremely rich like what you are describing.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 04-18-2005, 12:58 AM
Cobra Make, Engine: FFR 302 bored 306: 370HP
Send a message via AIM to phatry5
If it's an older holley definetly check your power valves, although you will usually have more problems than just heavy acceleration. You might want to check your plugs and distributor too. If leaning out doesn't fix it, try a 6AL to enhance your spark. Doesn't sound like timing, unless you are idleing rough and running hot.
Hold on tight!!!
Old 04-18-2005, 12:16 PM
jams's Avatar
From what you guys have described it just sounds like a rich condition.
I do have a Holley- a #6450 jumps into my head but it could also just be my pick 4 numbers.
I have never tuned a carb before where should I begin. All I know is you have to turn the adjustment screws and see how she idles.
Any help would be greatly appreciated.
Old 04-18-2005, 12:25 PM
Rich's Avatar
Jams, try these guys. They really helped me out.
http://www.holley.com/HiOctn/TechServ/TechServ.html
Rich
HTML code is On
