SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-18-2005, 08:52 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Default trunk shocks
Anyone installed spring shocks on your trunk to hold it open. I have the ROD, but it is a pain.
Old 05-18-2005, 11:35 PM
302cobra's Avatar
Cobra Make, Engine: Modified DRB 2000, 302 Windsor
Do you mean Gas struts?? I have seen them on a few cobras, they work pretty good. For authenticity, the click rod thingee is good.
Old 05-19-2005, 07:45 AM
Yea, the gas struts.
Old 05-19-2005, 11:53 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
Midstates offers the gas struts as an option for both hood & trunk. I did the hood ones because it holds the hood up higher and I don't thunk the hood on my noggin when I knock the rod out of the hole...
I sent the trunk ones back because I'm going to use the "click rod thingee" (I like that terminology!)
They should work for just about any kit... the brackets at the top are attached with blind threaded rivets (rivnuts) and the bottoms are attached to the hoop around the trunk opening.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 05-19-2005, 12:35 PM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Go here - http://www.mcmaster.com
Measure the length you need and don't go over 30#. you will need the mounting hardware - they have that too. Worked for both my hood and trunk.
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 05-20-2005, 08:14 AM
More great information! Thanks.
Bruce
HTML code is On
