February 2026
| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
06-12-2005, 08:10 PM
CA
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Smiths water / oil temp thread adaptors???
I am plumbing my Smiths (Caerbont made in 2001) oil temperature gauge. The threads on the capillary tube that goes into the oil pan end is a 5/8" UNF (unified fine thread).
Does anyone know where to get a high grade 308 or 316 stainless 5/8" UNF to 1/2" pipe adaptor. Both sides are male.
Thanks in advance,
Michael Strunk
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Advertising
06-12-2005, 09:49 PM
CA
5/8 UNF is also called 5/8-18 and 5/8 SAE
michael
06-13-2005, 01:39 AM
I used a standard "compression" type fitting adaptor, which of course was to small in the center for the thermistor (sensor) to pass through. So I drilled it out to the same size as the sensor. Works like a charm. I was never able to find an actual adaptor type fitting made for this application. I suspect such adaptors come with the gauge\sensor at the point of sale and if you don't get it then I don't know WHERE you would ever find it.
New Aviad road race pan replacing my old steel pan with welded in "bung" is why I needed one.
06-13-2005, 07:57 AM
TX
Cobra Make, Engine: Power Performance Body, Contemporary chassis, 427 CO, Big I/O toploader, AMP Billet rear, Trigo 6 pin
I had no issues with the water temp, fit right into the manifold. The oil temp fitting supplied was a BSPP(British standard parallel pipe) by 5/8-18 as you said. I didn't want to weld this fitting to the pan, and was unable to find a sealed bulkhead style fitting for the BSPP to screw into. I took a 5/8-18 bolt and drilled a 1/2 inch hole through it. Used teflon washers to seal on the pan, and inserted the probe through the bolt. Worked well.
Dave
06-13-2005, 08:25 AM
GA
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
Nisonger's in NY probably has what you need on the shelf. Also British American Transfer out of Sarasota FL. www.bat-inc.com
06-13-2005, 08:37 AM
TX
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Motorsports International has what you need. Call Marge at 619 390 9080
Bud
06-13-2005, 08:08 PM
CA
Thanks Bud Man... and everyone who chimed in.
michael
HTML code is On
