SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-07-2005, 07:41 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Don't mean to sound dumb, but????????
Trying to change a pulley on my alternator...which way does the big nut turn...normal, or reverse????????
Safe Flyin, errrrr Drivin, Earl
Old 08-07-2005, 07:52 PM
Rick Parker's Avatar
Normal
Rick
Old 08-07-2005, 08:07 PM
Ouch Ouch Hot Sand
Thanks Rick....I'll retackle it in the AM...just wanted to make sure I was going the right way...thats one "TOUGH" bugger.....
Old 08-07-2005, 08:42 PM
CC Member / Sponsor
Use an impact. It will spin right off.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 08-08-2005, 02:20 AM
Cobra Make, Engine: ERA
sounds like you might be removing an underdrive pulley?? i had problems with one.. get rid of them!!!
Old 08-08-2005, 05:48 AM
lovehamr's Avatar
Stolen Avitar
Tom's right, about the only way to take one off with out damaging anything is with an impact gun. Just as a side note; it's the only way that I've found to put one back on as well. Keep in mind that there aren't any "splines" or anything like that to hold it in place while you tighten the nut so you have nothing to hold on to without sticking something into the alternator which goes right back to the "damaging" thing. You may have one that will take a hex key in the shaft end (to hold it still) but I've never had any luck with those. Good luck.
Steve
Old 08-10-2005, 06:25 PM
Cobra Make, Engine: Unique FIA
Tighten it as much as you can. Install the alt and put the belt on tight. put the car in gear. Now tighten the rest of the way.
Steve
All my ex's live in Texas
HTML code is On
