Old 03-16-2006, 03:21 AM
Ant Ant is offline
Default Shifter lever offset modifications
My Cobra with Jerico five speed and Long shifter, the gear lever is way over to the left of the transmission tunnel, so what I am trying to do is get it over towards the middle as much as practical, before it comes through the floor. In order to do this I thought about bolting a 2" wide spacer block of aluminium on to the shifter to space the lever across, but this may put a twisting force leverage on the mechanism as the gear lever I will have to make will be bent a bit like a Cobra 427 shifter, this may be bad for shifting etc. I guess I should just build it and see if it works ok, but once holes are made etc its all work to change if not ok.
What I am considering is if you gear a force out from the operating center, instead of going up, down and across, the offset tends to add a circular twisting force into the equation?
A J. Newton
The 1960's rocked!
Old 03-16-2006, 04:07 AM
The original shift lever was not only angled forward, it was angled toward the driver by about 3". The same should work for you.
Old 03-16-2006, 02:40 PM
Ant Ant is offline
Default Gear lever position
Strictlypersonal,
What you are saying in lever shape, has the same affect as spacing on the shifter itself, so whether I do some spacing on the shifter and the most on the lever, the end result is the same in order to get from the shifter to the desired knob position!
I suppose its just the aesthetics of where it comes through the tunnel I am trying to improve, by moving the the point where it comes through the floor to look more central
A J. Newton
The 1960's rocked!
