SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-02-2006, 01:29 PM
Cobra Make, Engine: FFR #4227, 302; About to take delivery on B&B Street Coupe (Daytona)
Default Wet Sandpaper for Long Board
I've got one of the 18" variable flex long boards from Eastwood and want to use it for wet sanding/blocking the primer coat.
Problem is, I can't find any 400 grit or higher wet sanding paper to fit the board. Biggest wet sanding paper I've been able to find is 9" x 11".
Anybody know where to find any wet sanding paper in rolls or sheets that's 18" or longer?
Thanks in advance for your help.
Lawrence Perry
Old 08-02-2006, 02:02 PM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I would think that during wet sanding, you are not taking enough off to warrant a longboard. A good sanding block should be all that is needed. That may be why it's not available.
Old 08-02-2006, 05:05 PM
You've got a good point there. Not available because there's just no demand for it.
I would have thought you'd still want the flat surface a flexible long board can give you.
I've been using an 11" Dura-Block with 400 grit for the initial primer blocking so far and it's worked pretty well.
Thanks for the reply.
Lawrence Perry
Old 08-02-2006, 05:40 PM
Club Cobra Member
Cobra Make, Engine: Kirkham 482 ci alum block
I thougt you were talking about Surfboards... Wrong forum
Old 08-03-2006, 12:53 PM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
I used a piece of flexible nylon, 9" x 2" x 1/2 thick, with 400 grit wet sandpaper for all the curved surfaces, which is almost 80% of the car. For the flat surfaces, I used the 3M stickit 400 dry paper to get it flat, then wen't over it with a shorter block and 400 wet paper.
Before I primed the car, I blocked the entire body with 3M Stickit 180 grit paper with the 9" flexible block on the curved surfaces and a 17" board on the flat surfaces. After priming, the body was very flat when I blocked with 400 wet paper.
Snakebit
HTML code is On
