February 2026
Old 10-23-2006, 11:15 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default Non Cobra Question, Chev. (ugh) Camaro Question??
I have a friend restoring a 1968 Camaro ( I know, friends aren't suppose to let friends drive Chebbies...he-he) and in the original build manual, linked below, it makes reference to P.V., which we can't find anywhere any ideas or Chebby experts ?? Thanks..Earl
The confusing part was that the factory drawing listed the location at 114.25" PV and 28.94" PV with no description of what PV was.
http://firstgenfirebird.org/firebird...aRearPlace.jpg
Old 10-23-2006, 01:57 PM
Ron61's Avatar
Question
Earl,
In the picture that you attached it looks as if you are working on installing a radio antenna. I didn't see any reference to PV in that diagram and it looks to be a manual antenna. Is this so? I think some Cameros had an electric antenna but am not sure. I want to say it has something to do with vacuum, but just can't see from that diagram where you would need any vacuum.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-23-2006, 02:04 PM
Ouch Ouch Hot Sand
Hi Ron, the PV is in a little circle with numbers in it. I actually had a brainstorm after posting here and went to a Camaro ( please don't ban me from Club Cobra ) forum and found the answer.....PV means Plan View or Top View.....duhhhhhhhhhhhhhhhhhhhhh....now I know.............. and so does he................................
Old 10-23-2006, 02:08 PM
Ron61's Avatar
Smile
Earl,
Now we both know something about Cameros. Just remember it to impress the next person that runs into that with. LOL:
Ron 61
Ronnie Widener
Old 10-23-2006, 02:49 PM
ROUSHAC's Avatar
Earl,
P.V. in that drawing does refer to the point view - viewing a plane parallel to the ground.
However, it appears that someone had problems with that dimensioning and added numbers by hand to the drawing from the firewall, the back of the quarter panel, and the car's centerline to make it a bit easier to measure.
Just remember that even those handwriiten dimensions must be in a plane that is parallel to the ground not along the body which is not parallel to the ground. Use a long level and carpenters square to establish the initial points, and measure from there.
Cheers!
Dave
Dave
Old 10-23-2006, 03:34 PM
Banned
Measure it with a yardstick, mark it with chalk and cut it with a torch.
Old 10-23-2006, 03:55 PM
ROUSHAC's Avatar
That works too. After all, it's only a Ch*vy.
Cheers!
Dave
Dave
Old 10-24-2006, 12:24 AM
Here's a site for future reference on first generation Camaros:
Good luck.
Dan
Old 10-24-2006, 03:15 AM
Rick Parker's Avatar
Yoo guy speekn Chinee???
