SUPPORT OUR SPONSOR
  #21 (permalink)
Old 12-13-2006, 05:42 PM
Default success
Just as a follow up, this-worked-like-a-charm!! Tank hoses filter and pump are all in place. Thank you.
Steve
  #22 (permalink)
Old 12-13-2006, 06:11 PM
Cobra Make, Engine: CSX4000, 427
Originally Posted by Dan Stryffeler
Pony up and buy a braided hose cutter; $39.95 at Summit Racing SUM-900040. Just don't use it for anything else, (like trimming bushes, trees, etc.)
I had bought and tried that hose cutter, but it was too small, and didn't cut clean, and I eventually returned it. I then bought a much larger cable cutter from Harbor Freight, and it worked better, cut cleaner and easier, although a little cumbersom since it was bigger.
http://www.harborfreight.com/cpi/cta...temnumber=6649
I tried a cut off saw, but it creates too much metal and rubber dust. Even though I cleaned the hose after cutting it, I just was a little wary about still having some particles in the hose, so, for me, the harbor freight cable cutter is the best way so far.
In addition, I had used Earl's fittings, and they are hard to use. The fitting actually cuts into the end of the hose, as well as compresses it, when installing the fitting. Aeroquip fittings don't cut into the end of the hose, they just compres the end of the hose, and are easier to use. I will from now on use aeroquip.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #23 (permalink)
Old 12-14-2006, 04:57 AM
Cobra Make, Engine: Everett-Morrison, 434 cid
The jaws are a little small on the cable cutters and the Summit cutter and they don't cut as cleanly as they should. If you can justify the cost this cutter from Irvan-Smith works the best. This one cuts cleanly around all sides of the hose and will handle a -16 hose.
http://www.irvansmith.com/catalog2/p...e_cutter.shtml
Scott
Display Modes
HTML code is On
