SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-12-2007, 08:36 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
Default what you got for steering column
Just wondering what everyone has for a steering column? can't justify three hundred dollars for just a self canceling blinker switch. May try to modify a stock unit from the junkyard, and was wondering what most of the kits out there use. Patrick
Old 01-12-2007, 09:09 PM
Get hold of Roger Bollick at rgb@exact.com . He has all the parts for the steering column- the column, shafts, VW turns signal unit, hubs,etc... You'll have to buy the u-joints and steering wheel, but he will give you all the part numbers and suppliers.
I just got my shaft and column from Roger and they are very nice pieces.
Bob
Old 01-12-2007, 10:53 PM
1blackbb66's Avatar
Cobra Make, Engine: West Coast-450 HP 460
Mid eighties Ford Mustang driving a TRW rack in my West Coast.
Ray
Old 01-13-2007, 07:11 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I have an IDIDIT unit. I wish I had gotten the one with the high beams in the turn signal.
It is chrome and was easy to install, once I engineered the passage, but you will have to do that with any column.
Old 01-13-2007, 09:56 AM
Tommy's Avatar
When I went looking for a simple, inexpensive steering column, here's what I found and used: Speedway
Tommy
Previously owned EM Cobra
Old 01-17-2007, 04:09 PM
fsiewert's Avatar
Cobra Make, Engine: Old ('93)CMC kit, SB ford
I'm thinking early S-10; Tilt, Cruise, self canceling turn signal, emergency flashers, no column shift and I dont mind the locking column
Old 01-18-2007, 05:25 AM
Tilt/telescoping out of a 1988 Corvette. Made my own adapter for the Moto-Lita.
Works great when the wife wants to drive the car.
Old 01-18-2007, 03:41 PM
Cobra Make, Engine: B+B 351w #112
Mustang II or pinto.
Old 01-18-2007, 03:45 PM
flwolfman's Avatar
Cobra Make, Engine: None at moment
Mustang II
Old 01-18-2007, 05:43 PM
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Fasterpatric,
I made my steering column using the turn signal head from a '65 CORVAIR. I also used the steering shaft from the 'VAIR and mated it to a CHEVETTE lower half steering shaft. The 'VAIR shaft fitts inside the CHEVETTE lower shaft so I could adjust the length. I then cross drilled the two & bloted them together. I used a 1-1/2" steel tube for the housing.
There's a little more to it than that. E-mail me if you want more info.
Old 01-19-2007, 01:32 PM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
ShellValley cobras sell a complete steering column minus the steering wheel, it uses the VW type turning signal, which takes relays, or twin tail lights, they also sell a wooden steering wheel
PapaJohn
Old 01-21-2007, 04:25 PM
Thanks for all the input it definetly helped. You can see what I came up with on my scratch built thread.Patrick
HTML code is On
