SUPPORT OUR SPONSOR
Old 05-06-2007, 07:31 AM
Roscoe's Avatar
Default So I Destroy My Indestructible 9" Rear....
Well late last year I was out for a ride and the rear started making weird noises. I went to make a U to come back and on the exit ramp the rear actually locked up; as if I put the brakes on. Good thing nobody rearended me.
I had to muscle the car to move again and on the way back it was making a variety of terrible sounds. I winced all the way back. When I got back the rear was actually sizzling with smoke coming out of the vent. It stunk too.
I finally got around to pulling the center section. The paint on the casing was discolored from heat. The pinion bearing was completely destroyed.
Took it to a trans shop and the guy said the only servicable parts were the casing and the yoke. The pinion housing was toast too.
I just had it rebuilt and put it in yesterday. Bruce's Speed Shop in Rockaway, NJ did it. Car runs like a top.
The rear was one of the very few parts that was used. Came with my rolling chassis and I put about 25k on it.
Roscoe
Roscoe
Old 05-06-2007, 08:14 AM
Cobra Make, Engine: Just a collection of parts right now...
Send a message via MSN to spl310
Roscoe,
What was the reason for the failure? Sounds like it ran dry if the heat was that high.
Old 05-06-2007, 08:17 AM
Roscoe's Avatar
It looks like the rear might have run dry; although there was never a puddle under the car nor were the inside of the wheels oily. Just don't know. But it cost me nearly a grand to set it right.
Roscoe
Roscoe
Old 05-06-2007, 08:22 AM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
That's $111.11 per inch.Rearends seem to be overlooked quite ferquently.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 05-23-2007, 07:27 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
The lack of fluid is burn out from the rear end running so hot. Will boil the gear oil into sludge and burn the rubber on all the seals as well. From what I have seen in the shops, this usually happens when the pinion nut is WAY over torqued, binding the crush sleeve and dragging the pinion too high on the ring gear. I doubt it was low or empty of gear oil from the get go because you would have heard and felt it. Had anyone replaced the pinion seal for some reason? If not is was an assembly error. Just to be safe, I would run a high quality full synthetic gear oil (redline, Mobil1, etc) along the lines of a 75W90.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 05-24-2007, 05:58 AM
Roscoe's Avatar
Bob,
Thanks for the reply and info
The gear oil that came out of it was not sludgy, just black; and not alot of it. About 8 years ago I had a racing shop put a solid spacer in it. Other than that I did not touch it.
New one seems to be fine now.
Thanks again,
Roscoe
Roscoe
Old 05-24-2007, 08:05 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Originally Posted by Roscoe
Bob,
Thanks again,
Roscoe
Hey Roscoe. Sorry to hear about the failure. Does the above quote mean that you did not change the fluid for 8 years? I know you track you car. I burned up a 9 inch diff (Auburn Pro) and gears several years ago due to puking fluid out the breather. Replaced the gears and diff (True Trac) and fixed the puking breather. I try to change the fluid every other season now. I think that when I blow up this one I will go with an 8.8. I love the 9 but it is so damn heavy. Most of the axle folk say that aftermarket 8.8's (31 spline) are as tough as the 9.
Old 05-24-2007, 07:58 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Roscoe, good thing you were not run into while you were having this event.
Did you go with the same setup, or did you do any upgrades or changes?
Old 05-24-2007, 01:17 PM
Roscoe's Avatar
I went with the same setup. No changes.
Roscoe
Roscoe
Old 05-24-2007, 04:02 PM
Send a message via MSN to CowtownCobra
I think running it dry is the only way to kill a 9", the damn things are pretty indestructible
Old 05-25-2007, 05:35 AM
Roscoe's Avatar
You're supposed to change the oil????? I'll have to be more attentive to that. I'll put it on my maintenance sheet....really. I guess I should check the level every so often also.
Thanks,
Roscoe
Roscoe
Display Modes
HTML code is On
