SUPPORT OUR SPONSOR
Old 09-03-2007, 01:42 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Pusher fan problem
I lost one of the fan blade petals on one of my 9" pushers. Are the blades replacable on these things? I can't believe I would have to replace the whole twin fan assembly. Ouch!
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 09-03-2007, 01:47 PM
computerworks's Avatar
They should be simple metal fan blades, held onto the shaft of the motor with a collar and a set-screw....
...should be a pretty easy fix.
Old 09-03-2007, 03:16 PM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Yes, you can probably get a nice fan blad from either mcamaster-carr or grainger. Check out their web site, you will need to know the ID of the bore on the fan blade and the OD of the blade assembly.
Old 09-03-2007, 04:07 PM
I could use one of those for a change.
Old 09-03-2007, 08:32 PM
Cobra Make, Engine: Kirkham, 427 pond, twm 8 stack
I believe this is it:
http://www.grainger.com/Grainger/items/4C477
You need to see if your motors have 1/4" shafts.
I used these when I needed to replace mine.
Good luck!
Bill
Old 09-04-2007, 02:33 AM
Thanks Bill. I found the same part after doing a search. I pulled the bad one and it does have a quarter inch shaft. I have a Grainger not too far from the office.
Display Modes
HTML code is On
