SUPPORT OUR SPONSOR
Old 10-25-2007, 02:31 AM
Cobra Make, Engine: A & C Collectables
Default Ford 9" rear info
Does anyone have a drawing of proper install of ford 9" axles, including seal, bearing etc.
It has been years since I have done this stuff and not sure of proper installation. I beleive you need to press bearing on axle?
Please help!!
Old 10-25-2007, 05:15 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Default ford 9"
Yes, Check out the todays photos of a bunch of guys standing by a blue cobra with a big building in the back ground. In that grouping of pictures I found a good picture of a Ford 9".
Bill
Old 10-25-2007, 05:27 AM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Ford 9"
Yes, you have to press the bearings on the axles. The bearings I use have the seal, which is an o-ring, that is set into and around the outer edge of the bearings. I don't recall the bearing part numbers or specs, but I have the information and can probably find it if you need it. If you don't have the tool to press on the bearings, almost any shop can do it for you.
I had a seal that was starting to leak slightly about 4 years ago so I replaced both rear bearings and seals and everything has been dry since.
You can get the part number off your old bearing to order replacements.
Easy fix. Good luck, Bob
Old 10-25-2007, 08:09 AM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
I will try to post a photo that I have!!
Terry
Old 10-25-2007, 08:11 AM
One more time with a larger photo!! Hopefully!!
Terry
HTML code is On
