10-26-2007, 01:43 PM
WA
Large hoodscoop?
I'm looking for a large hoodscoop. I have an older EM replica with a full engine compartment. Oilpan is as low as reasonable and dual carbs are against the hood. As it sits now, I can only use two S&H aircleaners trimmed down to about 17/8 thick. The engine sits almost level so intake manifold has the dual carbs angled higher at the rear. I can modify things but scratch building I'm not much good at. I want to buy a hoodscoop that I can attach to my hood to get the aircleaner up above the hood line and into the air flow. The OEM scoop isn't high ,wide, or long enough . Ideally a scoop like the very rare Twin supercharged Cobras would be great. Any sources, suggestions, or allternatives?
Mike H
10-26-2007, 01:57 PM
Ill
EM has a hood with a larger scoop
10-26-2007, 02:20 PM
I have a mold to make the SuperSnake hood, drop me an E-mail and I'll send you a pic. Rcherv1228atAOL.com
10-26-2007, 07:52 PM
WV
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
I had my stock hood scoop cut out and a GT-350 hood scoop rivited and molded in. Works pretty good with the twin quads on my big block.
10-26-2007, 09:07 PM
Cobra Make, Engine: HM1035 with 521ci, 612fwhp
10-27-2007, 06:21 PM
WA
I tried several interpretations of the E-mail address,I got them both back. Try me at
mkes427@net-venture.com
Mike H
10-27-2007, 06:53 PM
I'll send some pics out tomorrow, (sunday) , let me know if you get them, thanks
10-27-2007, 08:43 PM
Cobra Make, Engine: TBD, other is 67 Mustang GTA 390 Convertible w/air,
Hood Scoop
ERA might be able to help you with the SuperSnake scoop. They built a replica several years ago.
10-28-2007, 05:20 AM
Mike , I sent pictures of the hood, and they got kicked back. I'll try again later today.
10-28-2007, 09:00 AM
Large scoop? Here is my scoop, its LARGE
Little bit to large for my taste. But i have not so many choises just now.
10-28-2007, 05:59 PM
ERA built 3 hoods and will not do any more
Michael C Henry ERA built 3, I got one on my car and the others are for Paxton clones. If you find last years Kit Car mag with the Run&Gun feature you will see my car on the front cover James Yale has the Red coupe as the main larger picture.  ( Hate hate you James) only kidding. There is a problem of the car gets light in the front end from TOO much air being pushed into the motor compartment. About 120 mph the lifting starts,  130 mph and the moving around starts. I learned this at Gateway. Rick L.
10-31-2007, 06:54 PM
Cobra Make, Engine: Lonestar 427 Comp. 351W
I built this cold air box for fun. It has a K&N 11" by 2 5/16" ring element and an 11" breather type lid. It is rated at 1050 cfm at 1.5 inches of H2O which is plenty for my little windsor.
It has the following features that I really like:
1) Gets cold air to the carb ( 1% HP gain per 11 F decrease in intake air temp)
2) It is very easy to take on and off, just remove the air filter and it comes off.
3) It does not interfere with anything else on the engine like the fuel lines and throttle linkage.
4) It was so easy to fabricate, even I could make it
Way to go Roscoe
11-01-2007, 05:48 PM
WA
My deal is I'm trying to get inline dual fours on a tunnel wedge intake manifold,some fresh air and less restrictive aircleaner elements. By less restricive I'll bet taller K&N elements on the S&H bases or an oval air cleaner with a descent element. The incline of the carb mounting flanges is more than the incline of the hood line. More than likely I'll have to come up higher through the hood and the rear will still be higher than the front .
Still no pictures of that super snake replica hood scoop.
Mike H
11-01-2007, 06:22 PM
Here is what the SC-110 looks like molded in (link provided in previous post)...
As for accomodating dual's I don't know - I had to put it on to get these large stacks under hood.
Best wishes and post pictures of what ever you go with!
11-01-2007, 06:27 PM
Just sent them to you again. They run thu this jackassed Kodak software, maybe that's what's blocking them
11-01-2007, 07:17 PM
I've put a few photos of my larger scoop here: http://www.firstcoastcobraclub.com/v...c.php?f=8&t=70
It allows a 4" high filter element, necessary for the 521 to breathe properly.
Tom
11-01-2007, 07:29 PM
Ok, Pics are now in my gallery
11-02-2007, 06:06 AM
Mr Bruce,
Nice
Tom
11-02-2007, 09:50 AM
WA
MR Bruce
The three pictures came through fine. I responded back.
Tom Wells
I take it the lip coming up from the original hood line inside the front of the scoop is to keep rain out from under the hood and off the distributor?
Mike H
11-02-2007, 10:25 AM
Mike,
Keeping the rain out is the theory. Not sure if it works, but the first one had no lip and to my eye, this one looks better.
I've run each in 1" per hour downpours - on and off for up to 2-1/2 hours - (how smart is that?) and no problems with water on the distributor. I use an MSD and it seems to be water-resistant enough.
Tom
